Datasheet LT1360 (Analog Devices) - 6
Description50MHz, 800V/µs Op Amp
Pages / Page16 / 6 — TYPICAL PERFORMANCE CHARACTERISTICS. Supply Current vs Supply Voltage. …
File Format / SizePDF / 229 Kb
TYPICAL PERFORMANCE CHARACTERISTICS. Supply Current vs Supply Voltage. Input Common Mode Range vs. Input Bias Current vs
TYPICAL PERFORMANCE CHARACTERISTICS Supply Current vs Supply Voltage Input Common Mode Range vs Input Bias Current vs
LT1360
W U TYPICAL PERFORMANCE CHARACTERISTICS Supply Current vs Supply Voltage Input Common Mode Range vs Input Bias Current vs and Temperature Supply Voltage Input Common Mode Voltage
0.6 6 V + V T S = ±15V – 0.5 A = 25°C T ∆V A = 25°C OS < 1mV 0.5 I + + I – 5 –1.0 I B B ———— µA) B = 2  125°C –1.5 0.4 4 –2.0 25°C 0.3 3 2.0 – 55°C 0.2 1.5 SUPPLY CURRENT (mA) 2 COMMON MODE RANGE (V) INPUT BIAS CURRENT ( 1.0 0.1 0.5 1 V – 0 0 5 10 15 20 0 5 10 15 20 –15 –10 –5 0 5 10 15 SUPPLY VOLTAGE (±V) SUPPLY VOLTAGE (±V) INPUT COMMON MODE VOLTAGE (V) 1360 G01 1360 G02 1360 G03
Input Bias Current vs Open-Loop Gain vs Temperature Input Noise Spectral Density Resistive Load
0.7 100 10 85 VS = ±15V V T + – S = ±15V A = 25°C 0.6 I + I INPUT CURRENT NOISE (pA/ V I B B T S = ±15V A = 25°C B =  ———— 2 AV = 101 80 √Hz) µA) R 0.5 S = 100k VS = ±5V 75 0.4 e i n n 10 1 0.3 70 0.2 OPEN-LOOP GAIN (dB) √ INPUT BIAS CURRENT ( Hz) 65 0.1 INPUT VOLTAGE NOISE (nV/ 0 1 0.1 60 – 50 –25 0 25 50 75 100 125 10 100 1k 10k 100k 10 100 1k 10k TEMPERATURE (°C) FREQUENCY (Hz) LOAD RESISTANCE (Ω) 1360 G04 1360 G05 1360 G06
Output Voltage Swing vs Output Voltage Swing vs Open-Loop Gain vs Temperature Supply Voltage Load Current
81 V + V + RL = 1k TA = 25°C V 80 – 0.5 S = ± 5V VO = ±12V –1 RL = 1k VIN = 100mV 85°C VS = ±15V –1.0 79 25°C –2 R –1.5 78 L = 500Ω – 40°C –3 –2.0 77 76 3 2.0 – 40°C 75 2 R OPEN-LOOP GAIN (dB) L = 500Ω 1.5 25°C 74 OUTPUT VOLTAGE SWING (V) OUTPUT VOLTAGE SWING (V) 1.0 1 RL = 1k 85°C 73 0.5 72 V – V – – 50 –25 0 25 50 75 100 125 0 5 10 15 20 – 50 – 40 –30 –20 –10 0 10 20 30 40 50 TEMPERATURE (°C) SUPPLY VOLTAGE (±V) OUTPUT CURRENT (mA) 1360 G07 1360 G08 1360 G09 6
