Datasheet LT1195 (Analog Devices) - 3
DescriptionLow Power, High Speed Operational Amplifier
Pages / Page12 / 3 — +5V ELECTRICAL CHARACTERISTICS TA = 25. – VS =. 5V, CL. 10pF, Pin 5 open …
File Format / SizePDF / 347 Kb
+5V ELECTRICAL CHARACTERISTICS TA = 25. – VS =. 5V, CL. 10pF, Pin 5 open circuit, unless otherwise noted. LT1195M/C. SYMBOL
+5V ELECTRICAL CHARACTERISTICS TA = 25 – VS = 5V, CL 10pF, Pin 5 open circuit, unless otherwise noted LT1195M/C SYMBOL
LT1195
C – VS =
5V, CL
10pF, Pin 5 open circuit, unless otherwise noted. LT1195M/C SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
IS Supply Current 12 16 mA Shutdown Supply Current Pin 5 at V – 0.8 1.5 mA IS/D Shutdown Pin Current Pin 5 at V – 5 25 µA tON Turn-On Time Pin 5 from V– to Ground, RL = 1k 160 ns tOFF Turn-Off Time Pin 5 from Ground to V –, RL = 1k 700 ns
C V + S = 5V, VS , = OV, VCM = 2.5V, CL
VOS Input Offset Voltage J8, N8 Package 3.0 9.0 mV S8 Package 3.0 11.0 mV IOS Input Offset Current 0.2 1.0 µA IB Input Bias Current ±0.5 ±2.0 µA Input Voltage Range (Note 4) 2.0 3.5 V CMRR Common Mode Rejection Ratio VCM = 2V to 3.5V 60 85 dB AVOL Large-Signal Voltage Gain RL = 150Ω to Ground, VOUT = 1V to 3V 0.5 3.0 V/mV VOUT Output Voltage Swing RL = 150Ω to Ground VOUT High 3.5 3.8 V VOUT Low 0.25 0.4 V SR Slew Rate AV = –1, VOUT = 1V to 3V 140 V/µs GBW Gain-Bandwidth Product 45 MHz IS Supply Current 11 15 mA Shutdown Supply Current Pin 5 at V – 0.8 1.5 mA IS/D Shutdown Pin Current Pin 5 at V – 5 25 µA
+5V ELECTRICAL CHARACTERISTICS –55
C
TA
125
C, (Note 11) VS =
5V, Pin 5 open circuit, unless otherwise noted. LT1195M SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VOS Input Offset Voltage 3.0 15.0 mV ∆VOS/∆T Input VOS Drift 17 µV/°C IOS Input Offset Current 0.2 2.0 µA IB Input Bias Current ±0.5 ±2.5 µA CMRR Common Mode Rejection Ratio VCM = –2.5V to 3.5V 55 85 dB PSRR Power Supply Rejection Ratio VS = ±2.375V to ±8V 55 80 dB AVOL Large-Signal Voltage Gain RL = 1k, VOUT = ±3V 1.50 5.0 V/mV RL = 150Ω, VOUT = ±3V 0.25 0.8 V/mV VOUT Output Voltage Swing RL = 1k ±3.7 ±3.9 V IS Supply Current 12 18 mA Shutdown Supply Current Pin 5 at V –, (Note 9) 0.8 2.5 mA IS/D Shutdown Pin Current Pin 5 at V – 5 25 µA 1195fa 3
