Datasheet RH37C (Analog Devices) - 2
DescriptionPrecision Operational Amplifier
Pages / Page4 / 2 — TABLE 1: ELECTRICAL CHARACTERISTICS (Preirradiation) (Note 9). TA = 25. …
File Format / SizePDF / 165 Kb
TABLE 1: ELECTRICAL CHARACTERISTICS (Preirradiation) (Note 9). TA = 25. SUB-. – 55. 125. SYMBOL PARAMETER. CONDITIONS. NOTES. MIN. TYP. MAX
TABLE 1: ELECTRICAL CHARACTERISTICS (Preirradiation) (Note 9) TA = 25 SUB- – 55 125 SYMBOL PARAMETER CONDITIONS NOTES MIN TYP MAX
RH37C
C SUB- – 55
C
T SUB- A
125
C SYMBOL PARAMETER CONDITIONS NOTES MIN TYP MAX GROUP MIN TYP MAX GROUP UNITS
en Input Noise Voltage 0.1Hz to 10Hz 4, 5 0.25 µVP-P Input Noise Voltage Density fO = 10Hz 3 8.0 nV/√Hz fO = 30Hz 4 5.6 nV/√Hz fO = 1000Hz 4 4.5 nV/√Hz in Input Noise Current Density fO = 1000Hz 4, 6 0.6 pV/√Hz Input Resistance 2 GΩ Common Mode Input Voltage Range 4 ±11 ±10.2 V CMRR Common Mode VCM = ±11V 100 1 dB Rejection Ratio VCM = ±10V 94 2, 3 dB PSRR Power Supply VS = ±4V to ±18V 94 1 dB Rejection Ratio VS = ±4.5V to ±18V 86 2, 3 dB AVOL Large-Signal Voltage Gain RL ≥ 2k, VO = ±10V 700 4 300 5, 6 V/mV RL ≥ 600Ω, VO = ±1V 4 200 V/mV VS = ±4V VOUT Maximum Output RL = 2k ±11.5 4 ±10.5 5, 6 V Voltage Swing RL = 600Ω ±10.0 4 V SR Slew Rate RL = 2k, AVCL ≥ 5 11 7 V/µs GBW Gain-Bandwidth Product fO = 10kHz (AVCL ≥ 5) 4 45 MHz fO = 1MHz (AVCL ≥ 5) 40 MHz ZO Open-Loop Output Resistance VO = 0, IO = 0 470 Ω PD Power Dissipation 170 1 mW
TABLE 1A: ELECTRICAL CHARACTERISTICS (Postirradiation) (Note 10) 10KRAD(Si) 20KRAD(Si) 50KRAD(Si) 100KRAD(Si) 200KRAD(Si) SYMBOL PARAMETER CONDITIONS NOTES MIN MAX MIN MAX MIN MAX MIN MAX MIN MAX UNITS
VOS Input Offset Voltage 1 100 130 180 280 400 µV IOS Input Offset Current 75 75 90 120 180 nA IB Input Bias Current ±80 ±80 ±125 ±200 ±400 nA Input Resistance 2 (Typ) 2 (Typ) 2 (Typ) 2 (Typ) 2 (Typ) GΩ Common Mode Input Voltage Range 4 ±11 ±11 ±11 ±11 ±11 V CMRR Common Mode VCM = ±11V 100 100 97 94 90 dB Rejection Ratio PSRR Power Supply VS = ±4V to ±18V 94 94 92 90 86 dB Rejection Ratio AVOL Large-Signal Voltage Gain RL ≥ 2k, VO = ±10V 700 700 700 700 400 V/mV VOUT Maximum Output RL ≥ 10k ±11.5 ±11.5 ±11.5 ±11.5 ±11.5 V Voltage Swing RL ≥ 600Ω ±10.0 ±10.0 ±10.0 ±10.0 ±10.0 V SR Slew Rate RL ≥ 2k 1.7 1.7 1.7 1.5 1 V/µs ZO Open-Loop Output Resistance VO = 0, IO = 0 70 (Typ) 70 (Typ) 70 (Typ) 70 (Typ) 70 (Typ) Ω PD Power Dissipation 170 170 170 170 170 mW 2
