Datasheet LT1007, LT1037 (Analog Devices) - 2
DescriptionLow Noise, High Speed Precision Operational Amplifiers
Pages / Page16 / 2 — ABSOLUTE MAXIMUM RATINGS (Note 1). (OBSOLETE). PACKAGE/ORDER INFORMATION. …
File Format / SizePDF / 532 Kb
ABSOLUTE MAXIMUM RATINGS (Note 1). (OBSOLETE). PACKAGE/ORDER INFORMATION. OBSOLETE PACKAGE. ELECTRICAL CHARACTERISTICS VS =
ABSOLUTE MAXIMUM RATINGS (Note 1) (OBSOLETE) PACKAGE/ORDER INFORMATION OBSOLETE PACKAGE ELECTRICAL CHARACTERISTICS VS =
LT1007/LT1037
W W W U ABSOLUTE MAXIMUM RATINGS (Note 1)
Supply Voltage .. ±22V Lead Temperature (Soldering, 10 sec.)... 300°C Input Voltage .. Equal to Supply Voltage Operating Temperature Range Output Short-Circuit Duration .. Indefinite LT1007/LT1037AC, C ... 0°C to 70°C Differential Input Current (Note 9) ... ± 25mA LT1007/LT1037I ... – 40°C to 85°C Storage Temperature Range ... – 65°C to 150°C LT1007/LT1037AM, M
(OBSOLETE)
– 55°C to 125°C
U W U PACKAGE/ORDER INFORMATION
TOP VIEW TOP VIEW VOS TRIM TOP VIEW VOS VOS V 8 OS V V 1 8 OS OS TRIM TRIM 1 7 V+ 1 8 TRIM TRIM TRIM – –IN 2 – 7 V+ – –IN 2 7 V+ –IN 2 6 OUT +IN 3 + 6 OUT + + +IN 3 6 OUT V– 4 5 NC 3 5 NC +IN V– 4 5 NC 4 V– (CASE) N8 PACKAGE S8 PACKAGE 8-LEAD PDIP H PACKAGE 8-LEAD PLASTIC SO T 8-LEAD TO-5 METAL CAN TJMAX = 150°C, θJA = 190°C/ W JMAX = 100°C, θJA = 130°C/ W (N8) TJMAX = 150°C, θJA = 150°C/ W, θJC = 45°C/ W ORDER PART NUMBER ORDER PART NUMBER ORDER PART NUMBER LT1007ACN8 LT1037ACN8 LT1007CS8 LT1037CS8 LT1007CN8 LT1037CN8 LT1007IS8 LT1037IS8 LT1007IN8 LT1037IN8 J8 PACKAGE LEAD CERDIP TJMAX = 150°C, θJA = 100°C/ W (J8) S8 PART MARKING LT1007ACJ8 LT1037ACJ8 LT1007ACH LT1037ACH 1007 1037 LT1007AMJ8 LT1037AMJ8 LT1007AMH LT1037AMH 1007I 1037I LT1007CJ8 LT1037CJ8 LT1007CH LT1037CH LT1007MJ8 LT1037MJ8 LT1007MH LT1037MH
OBSOLETE PACKAGE OBSOLETE PACKAGE
Consider the N8 Package for Alternate Source Consider the N8 or S8 Package for Alternate Source Consult LTC Marketing for parts specified with wider operating temperature ranges.
15V, TA = 25
C, unless otherwise noted. LT1007AC/AM LT1007C/I/M LT1037AC/AM LT1037C/I/M SYMBOL PARAMETER CONDITIONS MIN TYP MAX MIN TYP MAX UNITS
VOS Input Offset Voltage (Note 2) 10 25 20 60 µV ∆VOS Long Term Input Offset (Notes 3, 4) 0.2 1.0 0.2 1.0 µV/Mo ∆Time Voltage Stability IOS Input Offset Current 7 30 12 50 nA IB Input Bias Current ±10 ±35 ±15 ±55 nA en Input Noise Voltage 0.1Hz to 10Hz (Notes 4, 6) 0.06 0.13 0.06 0.13 µVP-P Input Noise Voltage Density fO = 10Hz (Notes 4, 5) 2.8 4.5 2.8 4.5 nV/√Hz fO = 1000Hz (Note 4) 2.5 3.8 2.5 3.8 nV/√Hz in Input Noise Current Density fO = 10Hz (Notes 4, 7) 1.5 4.0 1.5 4.0 pA/√Hz fO = 1000Hz (Notes 4, 7) 0.4 0.6 0.4 0.6 pA/√Hz sn100737 100737fbs 2
