Datasheet LT1007, LT1037 (Analog Devices) - 3
Description | Low Noise, High Speed Precision Operational Amplifiers |
Pages / Page | 16 / 3 — ELECTRICAL CHARACTERISTICS VS =. 15V, TA = 25. C, unless otherwise noted. … |
File Format / Size | PDF / 532 Kb |
ELECTRICAL CHARACTERISTICS VS =. 15V, TA = 25. C, unless otherwise noted. LT1007AC/AM. LT1007C/I/M. LT1037AC/AM. LT1037C/I/M. SYMBOL
LT1007/LT1037
15V, TA = 25
C, unless otherwise noted. LT1007AC/AM LT1007C/I/M LT1037AC/AM LT1037C/I/M SYMBOL PARAMETER CONDITIONS MIN TYP MAX MIN TYP MAX UNITS
Input Resistance, Common Mode 7 5 GΩ Input Voltage Range ±11.0 ±12.5 ±11.0 ±12.5 V CMRR Common Mode Rejection Ratio VCM = ±11V 117 130 110 126 dB PSRR Power Supply Rejection Ratio VS = ±4V to ±18V 110 130 106 126 dB AVOL Large-Signal Voltage Gain RL ≥ 2k, VO = ±12V 7.0 20.0 5.0 20.0 V/µV RL ≥ 1k, VO = ±10V 5.0 16.0 3.5 16.0 V/µV RL ≥ 600Ω, VO = ±10V 3.0 12.0 2.0 12.0 V/µV VOUT Maximum Output Voltage Swing RL ≥ 2k ±13.0 ±13.8 ±12.5 ±13.5 V RL ≥ 600Ω ±11.0 ±12.5 ±10.5 ±12.5 V SR Slew Rate LT1007 RL ≥ 2k 1.7 2.5 1.7 2.5 V/µs LT1037 A VCL ≥ 5 11 15 11 15 V/µs GBW Gain Bandwidth LT1007 fO = 100kHz (Note 8) 5.0 8.0 5.0 8.0 MHz Product LT1037 fO = 10kHz (Note 8) (AVCL ≥ 5) 45 60 45 60 MHz ZO Open-Loop Output Resistance VO = 0V, IO = 0 70 70 Ω PD Power Dissipation LT1007 80 120 80 140 mW LT1037 80 130 85 140 mW
The
denotes the specifications which apply over the temperature range 0
C
TA
70
C, VS =
15V, unless otherwise noted. LT1007AC LT1007C LT1037AC LT1037C SYMBOL PARAMETER CONDITIONS MIN TYP MAX MIN TYP MAX UNITS
VOS Input Offset Voltage (Note 2) ● 20 50 35 110 µV ∆VOS Average Input Offset Drift (Note 10) ● 0.2 0.6 0.3 1.0 µV/°C ∆Temp IOS Input Offset Current ● 10 40 15 70 nA IB Input Bias Current ● ±14 ±45 ±20 ±75 nA Input Voltage Range ● ±10.5 ±11.8 ±10.5 ±11.8 V CMRR Common Mode Rejection Ratio VCM = ±10.5V ● 114 126 106 120 dB PSRR Power Supply Rejection Ratio VS = ±4.5V to ±18V ● 106 126 102 120 dB AVOL Large-Signal Voltage Gain RL ≥ 2k, VO = ±10V ● 4.0 18.0 2.5 18.0 V/µV RL ≥ 1k, VO = ±10V ● 2.5 14.0 2.0 14.0 V/µV VOUT Maximum Output Voltage Swing RL ≥ 2k ● ±12.5 ±13.6 ±12.0 ±13.6 V PD Power Dissipation ● 90 144 90 160 mW sn100737 100737fbs 3
