Datasheet LT6000, LT6001, LT6002 (Analog Devices) - 6
DescriptionSingle, Dual and Quad, 1.8V, 13µA Precision Rail-to-Rail Op Amps
Pages / Page20 / 6 — ELECTRICAL CHARACTERISTICS The. denotes specifications which apply over …
File Format / SizePDF / 325 Kb
ELECTRICAL CHARACTERISTICS The. denotes specifications which apply over the full specified temperature
ELECTRICAL CHARACTERISTICS The denotes specifications which apply over the full specified temperature
LT6000/LT6001/LT6002
denotes specifications which apply over the full specified temperature range, otherwise specifications are TA = 25
C. VS = 5V, 0V, VCM = VOUT = 1/2 Supply. For the LT6000 and the LT6001DD, VSHDN = V+, unless otherwise noted. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VOH Output Swing High (Note 6) Input Overdrive = 30mV No Load ● 30 60 mV ISOURCE = 100µA ● 140 225 mV RL = 10k to GND ● 160 400 mV ISC Short-Circuit Current Short to GND 5 10 mA 0°C ≤ TA ≤ 70°C ● 4 mA –40°C ≤ TA ≤ 85°C ● 3 mA Short to V+ 3.5 7.5 mA 0°C ≤ TA ≤ 70°C ● 2.5 mA –40°C ≤ TA ≤ 85°C ● 1.5 mA IS Supply Current per Amplifier 15 18 µA 0°C ≤ TA ≤ 70°C ● 24 µA –40°C ≤ TA ≤ 85°C ● 27 µA VS = ±8V 20 25 µA ● 34 µA Total Supply Current in Shutdown (Note 7) VSHDN = 0.3V ● 3 5 µA ISHDN SHDN Pin Current (Note 7) VSHDN = 5V ● 0 30 nA VSHDN = 0V ● –1000 –650 nA Shutdown Output Leakage Current (Note 7) VSHDN = 0.3V (V– ≤ VOUT ≤ V+) ● 20 nA VL SHDN Pin Input Low Voltage (Note 7) ● 0.3 V VH SHDN Pin Input High Voltage (Note 7) ● 4.7 V tON Turn On Time (Note 7) VSHDN = 0V to 5V, RL = 10k 400 µs tOFF Turn Off Time (Note 7) VSHDN = 5V to 0V, RL = 10k 100 µs GBW Gain Bandwidth Product Freq = 1kHz 40 60 kHz 0°C ≤ TA ≤ 70°C ● 35 kHz –40°C ≤ TA ≤ 85°C ● 30 kHz SR Slew Rate AV = –1, VOUT = 0.5V to 4.5V 11 18 V/ms Measure 1V to 4V, 0°C ≤ TA ≤ 70°C ● 8 V/ms –40°C ≤ TA ≤ 85°C ● 6 V/ms FPBW Full Power Bandwidth (Note 9) VOUT = 4VP-P 0.87 1.4 kHz
Note 1:
Stresses beyond those listed under Absolute Maximum Ratings –40°C to 85°C but are not tested or QA sampled at these temperatures. may cause permanent damage to the device. Exposure to any Absolute The LT6000I/LT6001I/ LT6002I is guaranteed to meet specified Maximum Rating condition for extended periods may affect device performance from –40°C to 85°C. reliability and lifetime.
Note 5:
This parameter is not 100% tested.
Note 2:
A heat sink may be required to keep the junction temperature
Note 6:
Output voltage swings are measured between the output and below the absolute maximum. This depends on the power supply voltage power supply rails. and how many amplifiers are shorted. The θJA specified for the DD and
Note 7:
Specifications apply to the LT6000 or the LT6001DD with DHC packages is with minimal PCB heat spreading metal. Using expanded shutdown. metal area on all layers of a board reduces this value.
Note 8:
Guaranteed by correlation to slew rate at VS = 1.8V and GBW at
Note 3:
The LT6000C/LT6000I/LT6001C/LT6001I and LT6002C/LT6002I VS = 5V. are guaranteed functional over the temperature range of –40°C to 85°C.
Note 9:
Full-power bandwidth is calculated from the slew rate:
Note 4:
The LT6000C/LT6001C/LT6002C is guaranteed to meet specified FPBW = SR/πV performance from 0°C to 70°C. The LT6000C/LT6001C/LT6002C are P-P. designed, characterized and expected to meet specified performance from 600012fa 6
