LT1996 WWWUABSOLUTE AXI URATI GS (Note 1) Total Supply Voltage (V+ to V–) ... 40V Maximum Junction Temperature Input Voltage (Pins P9/M9, Note 2) ... ±60V DD Package .. 125°C Input Current MS Package ... 150°C (Pins P27/M27/P81/M81, Note 2) .. ±10mA Storage Temperature Range Output Short-Circuit Duration (Note 3) .. Indefinite DD Package ...–65°C to 125°C Operating Temperature Range (Note 4) ...–40°C to 85°C MS Package ..–65°C to 150°C Specified Temperature Range (Note 5) ..–40°C to 85°C MSOP–Lead Temperature (Soldering, 10 sec).. 300°C UWUPACKAGE/ORDER I FOR ATIO ORDER PART ORDER PART TOP VIEW NUMBER NUMBER P9 1 10 M9 TOP VIEW P27 2 9 M27 LT1996CDD P9 1 10 M9 LT1996CMS P81 3 8 M81 P27 2 9 M27 LT1996IDD LT1996IMS P81 3 8 M81 V 4 7 V EE CC V 4 LT1996ACDD EE 7 VCC LT1996ACMS REF 5 6 OUT REF 5 6 OUT LT1996AIDD LT1996AIMS MS PACKAGE DD PACKAGE 10-LEAD PLASTIC MSOP 10-LEAD (3mm × 3mm) PLASTIC DFN DD PART MARKING* TJMAX = 150°C, θJA = 230°C/W MS PART MARKING* TJMAX = 125°C, θJA = 160°C/W UNDERSIDE METAL CONNECTED TO VEE LBPC LTBPB (PCB CONNECTION OPTIONAL) *Temperature and electrical grades are identified by a label on the shipping container. Consult LTC Marketing for parts specified with wider operating temperature ranges. ELECTRICAL CHARACTERISTICS The ● denotes the specifications which apply over the full operatingtemperature range, otherwise specifications are at TA = 25 ° C. Difference amplifier configuration, VS = 5V, 0V or ± 15V;VCM = VREF = half supply, unless otherwise noted.SYMBOLPARAMETERCONDITIONSMINTYPMAXUNITS ∆G Gain Error VS = ±15V, VOUT = ±10V; RL = 10k G = 81; LT1996AMS ● ±0.02 ±0.05 % G = 27; LT1996AMS ● ±0.03 ±0.06 % G = 9; LT1996AMS ● ±0.03 ±0.07 % G = 81; LT1996ADD ● ±0.02 ±0.05 % G = 27; LT1996ADD ● ±0.02 ±0.07 % G = 9; LT1996ADD ● ±0.03 ±0.08 % G = 81; LT1996 ● ±0.04 ±0.12 % G = 27; LT1996 ● ±0.04 ±0.12 % G = 9; LT1996 ● ±0.04 ±0.12 % GNL Gain Nonlinearity VS = ±15V; VOUT = ±10V; RL = 10k; G = 9 ● 1 10 ppm ∆G/∆T Gain Drift vs Temperature (Note 6) VS = ±15V; VOUT = ±10V; RL = 10k ● 0.3 3 ppm/°C CMRR Common Mode Rejection Ratio, VS = ±15V; G = 9; VCM = ±15.3V Referred to Inputs (RTI) LT1996AMS ● 80 100 dB LT1996ADD ● 80 100 dB LT1996 ● 70 100 dB VS = ±15V; G = 27; VCM = –14.5V to 14.3V LT1996AMS ● 95 105 dB LT1996ADD ● 90 105 dB LT1996 ● 75 105 dB 1996f 2
