LT1678/LT1679 Dual/Quad Low Noise, Rail-to-Rail, Precision Op Amps UFEATURESDESCRIPTIO ■ Rail-to-Rail Input and Output The LT®1678/LT1679 are dual/quad rail-to-rail op amps ■ 100% Tested Low Voltage Noise: offering both low noise and precision: 3.9nV/√Hz wideband 3.9nV/ √ Hz Typ at 1kHz noise, 1/f corner frequency of 4Hz and 90nV peak-to-peak 5.5nV/ √ Hz Max at 1kHz 0.1Hz to 10Hz noise are combined with outstanding ■ Single Supply Operation from 2.7V to 36V precision: 100µV maximum offset voltage, greater than ■ Offset Voltage: 100 µ V Max 100dB common mode and power supply rejection and ■ Low Input Bias Current: 20nA Max 20MHz gain bandwidth product. The LT1678/LT1679 bring ■ High AVOL: 3V/µV Min, RL = 10k precision as well as low noise to single supply applications as ■ High CMRR: 100dB Min low as 3V. The input range exceeds the power supply by ■ High PSRR: 106dB Min 100mV with no phase inversion while the output can swing ■ Gain Bandwidth Product: 20MHz to within 170mV of either rail. ■ Operating Temperature Range: – 40°C to 85°C The LT1678/LT1679 are offered in the SO-8 and SO-14 ■ Matching Specifications packages. A full set of matching specifications are also ■ No Phase Inversion provided, facilitating their use in matching dependent appli- ■ 8-Lead SO and 14-Lead SO Packages U cations such as a two op amp instrumentation amplifier APPLICATIO S design. The LT1678/LT1679 are specified for supply volt- ages of ±15V, single 5V as well as single 3V. For a single ■ Strain Gauge Amplifiers amplifier with similiar performance, see the LT1677 data ■ Portable Microphones sheet. ■ Battery-Powered Rail-to-Rail Instrumentation ■ Low Noise Signal Processing , LTC and LT are registered trademarks of Linear Technology Corporation. ■ Microvolt Accuracy Threshold Detection ■ Infrared Detectors UTYPICAL APPLICATIOInstrumentation Amplifier with Shield Driver 3 0.1Hz to 10Hz Voltage Noise + 1/4 1 1k 30k LT1679 VS = ±2.5V 2 – RF 3.4k 15V 5 4 GUARD + RG 1/4 7 100Ω OUTPUT + 10 LT1679 6 + – 8 1/4 11 RG 30k INPUT LT1679 – 100Ω – 9 –15V VOLTAGE NOISE (50nV/DIV) GUARD GAIN = 1000 13 R 0 2 4 6 8 10 – F 3.4k TIME (sec) 1/4 14 16789 TA01 LT1679 16789 TA01b 12 + 1k sn16789 16789fs 1
