Datasheet LT1218, LT1219 (Analog Devices) - 8
DescriptionPrecision Rail-to-Rail Input and Output Op Amps
Pages / Page16 / 8 — TYPICAL PERFORMANCE CHARACTERISTICS. VOS Distribution, VCM = 0V. OS …
File Format / SizePDF / 329 Kb
TYPICAL PERFORMANCE CHARACTERISTICS. VOS Distribution, VCM = 0V. OS Shift, VCM = 0V to 5V. OS Distribution, VCM = 5V
TYPICAL PERFORMANCE CHARACTERISTICS VOS Distribution, VCM = 0V OS Shift, VCM = 0V to 5V OS Distribution, VCM = 5V
LT1218/LT1219
W U TYPICAL PERFORMANCE CHARACTERISTICS VOS Distribution, VCM = 0V V V OS Shift, VCM = 0V to 5V OS Distribution, VCM = 5V
30 40 30 VS = 5V, 0V VS = 5V, 0V VS = 5V, 0V VCM = 0V 35 VCM = 0V TO 5V VCM = 5V 25 25 30 20 20 25 15 20 15 15 10 10 PERCENT OF UNITS (%) PERCENT OF UNITS (%) 10 PERCENT OF UNITS (%) 5 5 5 0 0 0 –100 –60 –20 20 60 100 –100 –60 –20 20 60 100 –100 –60 –20 20 60 100 INPUT OFFSET VOLTAGE (µV) INPUT OFFSET VOLTAGE (µV) INPUT OFFSET VOLTAGE (µV) LT1218/19 • TPC01 LT1218/19 • TPC02 LT1218/19 • TPC03
Input Bias Current vs Supply Current vs Temperature Minimum Supply Voltage Common Mode Voltage
500 200 50 VS = 5V, 0V TA = –40°C VS = ±15V µV) 400 150 25 µA) TA = 25°C TA = 25°C VS = ±2.5V TA = 85°C 300 100 TA = – 40°C TA = 85°C 0 200 50 SUPPLY CURRENT ( INPUT BIAS CURRENT (nA) –25 100 0 TA = 25°C CHANGE IN OFFSET VOLTAGE ( 0 –50 –50 –40 –20 0 20 40 60 80 100 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 –1 0 1 2 3 4 5 6 7 TEMPERATURE (°C) TOTAL SUPPLY VOLTAGE (V) COMMON MODE VOLTAGE (V) LT1218/19 • TPC04 LT1218/19 • TPC05 LT1218/19 • TPC06
Output Saturation Voltage vs Output Saturation Voltage vs 0.1Hz to 10Hz Output Load Current (Output Low) Load Current (Output High) Voltage Noise
10 10 VS = 5V, 0V VS = 5V, 0V VS = ±2.5V VCM = 0V 1 1 TA = 85°C TA = 25°C 0.1 T 0.1 A = 25°C TA = –40°C TA = 85°C SATURATION VOLTAGE (V) 0.01 0.01 T SATURATION VOLTAGE (V) A = –40°C OUTPUT VOLTAGE (400nV/DIV) 0.001 0.001 0.001 0.01 0.1 1 10 0.001 0.01 0.1 1 10 TIME (1s/DIV) LOAD CURRENT (mA) LOAD CURRENT (mA) LT1218/19 • TPC07 LT1218/19 • TPC08 LT1218/19 • TPC09 8
