Datasheet LT1880 (Analog Devices) - 2
DescriptionSOT-23, Rail-to-Rail Output, Picoamp Input Current Precision Op Amp
Pages / Page12 / 2 — ABSOLUTE MAXIMUM RATINGS. PIN CONFIGURATION. (Note 1). ORDER INFORMATION. …
File Format / SizePDF / 233 Kb
ABSOLUTE MAXIMUM RATINGS. PIN CONFIGURATION. (Note 1). ORDER INFORMATION. LEAD FREE FINISH. TAPE AND REEL. PART MARKING
ABSOLUTE MAXIMUM RATINGS PIN CONFIGURATION (Note 1) ORDER INFORMATION LEAD FREE FINISH TAPE AND REEL PART MARKING
LT1880
Supply Voltage (V+ to V–) ...40V TOP VIEW Differential Input Voltage (Note 2) .. ±10V OUT 1 5 V+ Input Voltage ..V+ to V– V– 2 Input Current (Note 2) .. ±10mA +IN 3 4 –IN Output Short-Circuit Duration (Note 3) .. Indefi nite S5 PACKAGE 5-LEAD PLASTIC TSOT-23 Operating Temperature Range (Note 4) ...– 40°C to 85°C TJMAX = 150°C, θJA = 250°C/W Specifi ed Temperature Range (Note 5) ..– 40°C to 85°C Maximum Junction Temperature .. 150°C Storage Temperature Range .. –65°C to 150°C Lead Temperature (Soldering, 10 sec)... 300°C
ORDER INFORMATION LEAD FREE FINISH TAPE AND REEL PART MARKING PACKAGE DESCRIPTION SPECIFIED TEMPERATURE RANGE
LT1880CS5#PBF LT1880CS5#TRPBF LTUM 5-Lead Plastic TSOT-23 0°C to 70°C LT1880IS5#PBF LT1880IS5#TRPBF LTVW 5-Lead Plastic TSOT-23 –40°C to 85°C Consult LTC Marketing for parts specifi ed with wider operating temperature ranges. Consult LTC Marketing for information on non-standard lead based fi nish parts. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifi cations, go to: http://www.linear.com/tapeandreel/
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. VS = 5V, 0V; VCM = 2.5V unless otherwise noted. (Note 5) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VOS Input Offset Voltage 40 150 μV 0°C < T l A < 70°C 200 μV –40°C < T l 250 μV A < 85°C Input Offset Voltage Drift 0°C < TA < 70°C l 0.3 1.2 μV/°C (Note 6) –40°C < T l A < 85°C 0.3 1.2 μV/°C IOS Input Offset Current 150 900 pA 0°C < T l A < 70°C 1200 pA –40°C < T l 1400 pA A < 85°C IB Input Bias Current 150 900 pA 0°C < T l A < 70°C 1200 pA –40°C < T l 1500 pA A < 85°C Input Noise Voltage 0.1Hz to 10Hz 0.5 μVp-p en Input Noise Voltage Density f = 1kHz 13 nV/√Hz in Input Noise Current Density f = 1kHz 0.07 pA/√Hz RIN Input Resistance Differential 380 MΩ Common Mode, VCM = 1V to 3.8V 210 GΩ CIN Input Capacitance 3.7 pF VCM Input Voltage Range l (V– + 1.0) (V+ – 1.2) V 1880fa 2
