Datasheet LT1784 (Analog Devices) - 2
Description2.5MHz, Over-The-Top Low Power, Rail-to-Rail Input and Output Op Amp in SOT-23
Pages / Page12 / 2 — ABSOLUTE MAXIMUM RATINGS (Note 1). PIN CONFIGURATION. ORDER INFORMATION. …
File Format / SizePDF / 204 Kb
ABSOLUTE MAXIMUM RATINGS (Note 1). PIN CONFIGURATION. ORDER INFORMATION. LEAD FREE FINISH. TAPE AND REEL. PART MARKING
ABSOLUTE MAXIMUM RATINGS (Note 1) PIN CONFIGURATION ORDER INFORMATION LEAD FREE FINISH TAPE AND REEL PART MARKING
LT1784
Total Supply Voltage (V+ to V–) ...18V Operating Temperature Range (Note 10).. –40°C to 85°C Input Differential Voltage ..18V Specifi ed Temperature Range (Note 11) .. –40°C to 85°C Input Pin Voltage to V– .. +24V/–10V Junction Temperature ... 150°C Shutdown Pin Voltage Above V– ..18V Storage Temperature Range .. –65°C to 150°C Shutdown Pin Current ...±10mA Lead Temperature (Soldering, 10 sec) .. 300°C Output Short-Circuit Duration (Note 2) .. Indefi nite
PIN CONFIGURATION
TOP VIEW TOP VIEW OUT 1 5 V+ OUT 1 6 V+ V– 2 V– 2 5 SHDN + – + – +IN 3 4 –IN +IN 3 4 –IN S5 PACKAGE S6 PACKAGE 5-LEAD PLASTIC TSOT-23 6-LEAD PLASTIC TSOT-23 TJMAX = 150°C, θJA = 250°C/W TJMAX = 150°C, θJA = 230°C/W
ORDER INFORMATION LEAD FREE FINISH TAPE AND REEL PART MARKING PACKAGE DESCRIPTION SPECIFIED TEMPERATURE RANGE
LT1784CS5#PBF LT1784CS5#TRPBF LTJD 5-Lead Plastic TSOT-23 –40°C to 85°C LT1784IS5#PBF LT1784IS5#TRPBF LTSN 5-Lead Plastic TSOT-23 –40°C to 85°C LT1784CS6#PBF LT1784CS6#TRPBF LTIW 6-Lead Plastic TSOT-23 –40°C to 85°C LT1784IS6#PBF LT1784IS6#TRPBF LTIX 6-Lead Plastic TSOT-23 –40°C to 85°C Consult LTC Marketing for parts specifi ed with wider operating temperature ranges. Consult LTC Marketing for information on non-standard lead based fi nish parts. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifi cations, go to: http://www.linear.com/tapeandreel/
denotes the specifi cations which apply over the specifi ed temperature range, otherwise specifi cations are at TA = 25°C. VS = 3V, 0V; VS = 5V, 0V, VCM = VOUT = half supply, for the 6-lead part VPIN5 = 0V, pulse power tested unless otherwise specifi ed. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VOS Input Offset Voltage TA = 25°C 1.5 3.5 mV 0°C ≤ TA ≤ 70°C l 4.2 mV –40°C ≤ TA ≤ 85°C l 4.5 mV ΔVOS/ΔT Input Offset Voltage Drift (Note 7) –40°C ≤ TA ≤ 85°C l 5 15 μV/°C IOS Input Offset Current l 25 50 nA VCM = 18V (Note 3) l 50 μA 1784fa 2
