Datasheet LT1784 (Analog Devices) - 3
Description2.5MHz, Over-The-Top Low Power, Rail-to-Rail Input and Output Op Amp in SOT-23
Pages / Page12 / 3 — ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply …
File Format / SizePDF / 204 Kb
ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply over the specifi ed
ELECTRICAL CHARACTERISTICS The denotes the specifi cations which apply over the specifi ed
LT1784
denotes the specifi cations which apply over the specifi ed temperature range, otherwise specifi cations are at TA = 25°C. VS = 3V, 0V; VS = 5V, 0V, VCM = VOUT = half supply, for the 6-lead part VPIN5 = 0V, pulse power tested unless otherwise specifi ed. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
IB Input Bias Current l 250 500 nA VCM = 18V (Note 3) l 225 400 μA SHDN or VS = 0V, VCM = 0V to 18V 0.1 nA ΔIB/ΔT Input Bias Current Drift –40°C ≤ TA ≤ 85°C l 0.4 nA/°C Input Noise Voltage 0.1Hz to 10Hz 1.5 μVP-P en Input Noise Voltage Density f = 10kHz 25 nV/√Hz in Input Noise Current Density f = 10kHz 0.3 pA/√Hz RIN Input Resistance Differential 100 200 kΩ Common Mode, VCM = 0V to (VCC – 1.2V) 150 MΩ Common Mode, VCM = 0V to 18V 45 80 kΩ CIN Input Capacitance 5 pF VCM Input Voltage Range l 0 18 V CMRR Common Mode Rejection Ratio VCM = 0V to VCC – 1.2V l 84 95 dB (Note 3) VCM = 0V to 18V (Note 6) l 60 70 dB PSRR Power Supply Rejection Ratio VS = 3V to 12.5V, VCM = VO = 1V l 90 100 dB AVOL Large-Signal Voltage Gain VS = 3V, VO = 500mV to 2.5V, RL = 10k 133 1000 V/mV VS = 3V, 0°C ≤ TA ≤ 70°C l 90 V/mV VS = 3V, –40°C ≤ TA ≤ 85°C l 60 V/mV VS = 5V, VO = 500mV to 4.5V, RL = 10k 266 1000 V/mV VS = 5V, 0°C ≤ TA ≤ 70°C l 180 V/mV VS = 5V, –40°C ≤ TA ≤ 85°C l 120 V/mV VOL Output Voltage Swing LOW No Load l 4 10 mV ISINK = 5mA l 200 400 mV VS = 5V, ISINK = 10mA l 350 600 mV VOH Output Voltage Swing HIGH VS = 3V, No Load l 2.885 2.93 V VS = 3V, ISOURCE = 3mA l 2.600 2.8 V VS = 5V, No Load l 4.885 4.93 V VS = 5V, ISOURCE = 10mA l 4.400 4.7 V ISC Short-Circuit Current (Note 2) VS = 3V, Short to GND 4 7.5 mA VS = 3V, Short to VCC 15 30 mA VS = 5V, Short to GND 12.5 22 mA VS = 5V, Short to VCC 20.0 40 mA Minimum Supply Voltage l 2.5 2.7 V Reverse Supply Voltage IS = –100μA l 18 V IS Supply Current 500 750 μA (Note 4) l 900 μA Supply Current, Shutdown VPIN5 = 2V, No Load (Note 8) l 7 18 μA ISHDN SHDN Pin Current VPIN5 = 0.3V (On), No Load (Note 8) l 0.5 nA VPIN5 = 2V (Shutdown), No Load (Note 8) l 2.0 8 μA VPIN5 = 5V (Shutdown), No Load (Note 8) 5.0 μA Output Leakage Current, Shutdown VPIN5 = 2V, No Load (Note 8) l 0.05 1 μA Maximum SHDN Pin Current VPIN5 = 18V, No Load (Note 8) l 10 30 μA VIL SHDN Pin Input Low Voltage (Note 8) l 0.3 V VIH SHDN Pin Input High Voltage (Note 8) l 2 V tON Turn-On Time VPIN5 = 5V to 0V, RL = 10k (Note 8) 18 μs tOFF Turn-Off Time VPIN5 = 0V to 5V, RL = 10k (Note 8) 2.2 μs 1784fa 3
