LT1784 ELECTRICAL CHARACTERISTICSThe l denotes the specifi cations which apply over the specifi edtemperature range, otherwise specifi cations are at TA = 25°C. VS = ±5V, VCM = 0V, VOUT = 0V, for the 6-lead part VPIN5 = V–,pulse power tested unless otherwise specifi ed.SYMBOLPARAMETERCONDITIONSMINTYPMAXUNITS VIL SHDN Pin Input Low Voltage VS = ±5V (Note 8) l –4.7 V VIH SHDN Pin Input High Voltage VS = ±5V (Note 8) l –3 V tON Turn-On Time VPIN5 = 0V to –5V, RL = 10k (Note 8) l 18 μs tOFF Turn-Off Time VPIN5 = –5V to 0V, RL = 10k (Note 8) l 2.2 μs GBW Gain Bandwidth Product f = 5kHz 1.55 2.6 MHz 0°C ≤ TA ≤ 70°C l 1.30 MHz –40°C ≤ TA ≤ 85°C l 1.20 MHz SR Slew Rate AV = –1, RL = ∞, VO = ±4V, Measured at VO = ±2V 1.3 2.2 V/μs 0°C ≤ T l A ≤ 70°C 1.2 V/μs –40°C ≤ T l A ≤ 85°C 1.1 V/μs FPBW Full-Power Bandwidth (Note 9) VOUT = 8VP-P 94 kHz tS Settling Time VS = 5V, ΔVOUT = 4V to 0.1%, AV = 1 3.4 μs Note 1: Stresses beyond those listed under Absolute Maximum Ratings Note 6: This specifi cation implies a typical input offset voltage of 5.7mV at may cause permanent damage to the device. Exposure to any Absolute VCM = 18V and a maximum input offset voltage of 18mV at VCM = 18V. Maximum Rating condition for extended periods may affect device Note 7: This parameter is not 100% tested. reliability and lifetime. Note 8: Specifi cations apply to 6-lead SOT-23 with shutdown. Note 2: A heat sink may be required to keep the junction temperature Note 9: Full-power bandwidth is calculated from the slew rate. below absolute maximum. FPBW = SR/2πVP. Note 3: VS = 5V limits are guaranteed by correlation to VS = 3V and Note 10: The LT1784C is guaranteed functional over the operating VS = ±5V or VS = ±9V tests. temperature range –40°C to 85°C. Note 4: VS = 3V limits are guaranteed by correlation to VS = 5V and Note 11: The LT1784C is guaranteed to meet specifi ed performance from VS = ±5V or VS = ±9V tests. 0°C to 70°C. The LT1784C is designed, characterized and expected to Note 5: Guaranteed by correlation to slew rate at VS = ±5V, and GBW at meet specifi ed performance from –40°C to 85°C but is not tested or QA VS = 5V and VS = ±5V tests. sampled at these temperatures. LT1784I is guaranteed to meet specifi ed performance from –40°C to 85°C. TYPICAL PERFORMANCE CHARACTERISTICSOutput VoltageSupply Current vs Supply VoltageMinimum Supply Voltagevs Large Input Voltage 700 400 5 VS = 5V, 0V 650 300 4 600 TA = 125°C 200 550 TA = 25°C 100 T 3 T A = –55°C A = 125°C (V) 500 0 T OUT Y CURRENT (μA) A = 25°C V 2 5V 450 T –100 A = –55°C SUPPL V + IN 400 –200 1 – 350 INPUT OFFSET VOLTAGE CHANGE (μV) –300 300 –400 0 2 4 6 8 10 12 14 16 18 1 2 3 4 5 –10 –6 –2 2 6 10 14 18 SUPPLY VOLTAGE (V) TOTAL SUPPLY VOLTAGE (V) VIN (V) 1784 G01 1784 G02 1784 G03 1784fa 5
