Datasheet LT1783 (Analog Devices) - 6
Description1.25MHz, Over-The-Top Micropower, Rail-to-Rail Input and Output Op Amp in SOT-23
Pages / Page16 / 6 — ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply …
File Format / SizePDF / 183 Kb
ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply over the full operating
ELECTRICAL CHARACTERISTICS The denotes the specifi cations which apply over the full operating
LT1783
l
denotes the specifi cations which apply over the full operating temperature range of –40°C ≤ TA ≤ 125°C. VS = 3V, 0V; VS = 5V, 0V; VCM = VOUT = half supply, for the 6-lead part VPIN5 = 0V, pulse power tested unless otherwise specifi ed. (Note 4) LT1783H SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
Minimum Supply Voltage l 2.7 V Reverse Supply Voltage IS = –100μA l 18 V IS Supply Current 210 300 μA l 600 μA Supply Current, SHDN VPIN5 = 2V, No Load (Note 10) l 25 μA ISHDN Shutdown Pin Current VPIN5 = 0.3V, No Load (Note 10) l 0.5 nA VPIN5 = 2V, No Load (Note 10) l 12 μA Output Leakage Current VPIN5 = 2V, No Load (Note 10) l 2.5 μA Maximum Shutdown Pin Current VPIN5 = 18V, No Load (Note 10) l 40 μA GBW Gain Bandwidth Product f = 5kHz (Note 5) 750 1250 kHz l 400 kHz SR Slew Rate AV = –1, RL = ∞ (Note 7) 0.24 0.42 V/μs l 0.12 V/μs
The
l
denotes the specifi cations which apply over the full operating temperature range of –40°C ≤ TA ≤ 125°C. VS = ±5V, VCM = 0V, VOUT = 0V, VSHDN = V–, TA = –40°C to 125°C, for the 6-lead part VPIN5 = V–, pulse power tested unless otherwise specifi ed. (Note 4) LT1783H SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VOS Input Offset Voltage 500 950 μV l 3.1 mV Input Offset Voltage Drift (Note 9) l 15 μV/°C IOS Input Offset Current l 15 nA IB Input Bias Current l 150 nA CMRR Common Mode Rejection Ratio VCM = –4.7V to 13V l 60 dB AVOL Large-Signal Voltage Gain VO = ±4V, RL = 10k 70 160 V/mV l 10 V/mV VO Output Voltage Swing No Load l ±4.85 V IOUT = ±5mA l ±4.20 V IOUT = ±10mA l ±3.80 V PSRR Power Supply Rejection Ratio VS = ±1.5V to ±9V l 80 dB Minimum Supply Voltage l ±1.35 V IS Supply Current 230 325 μA l 650 μA Supply Current, SHDN VPIN5 = –3V, VS = ±5V, No Load (Note 10) l 25 μA ISHDN Shutdown Pin Current VPIN5 = –4.7V, VS = ±5V, No Load (Note 10) l 0.5 nA VPIN5 = –3V, VS = ±5V, No Load (Note 10) l 12 μA Maximum Shutdown Pin Current VPIN5 = 9V, VS = ±9V (Note 10) l 45 μA Output Leakage Current VPIN5 = –7V, VS = ±9V, No Load l 3 μA VL Shutdown Pin Input Low Voltage VS = ±5V l –4.7 V VH Shutdown Pin Input High Voltage VS = ±5V l –2.8 V GBW Gain Bandwidth Product f = 5kHz 800 1300 kHz l 425 kHz SR Slew Rate AV = –1, RL = ∞, VO = 4V 0.26 0.45 V/μs Measured at VO = ±2V l 0.14 V/μs 1783fd 6
