Datasheet LT1782 (Analog Devices) - 8
Description | Micropower, Over-The-Top SOT-23, Rail-to-Rail Input and Output Op Amp |
Pages / Page | 16 / 8 — TYPICAL PERFORMANCE CHARACTERISTICS. Output Voltage. Supply Current vs … |
File Format / Size | PDF / 527 Kb |
TYPICAL PERFORMANCE CHARACTERISTICS. Output Voltage. Supply Current vs Supply Voltage. Minimum Supply Voltage
LT1782
TYPICAL PERFORMANCE CHARACTERISTICS Output Voltage Supply Current vs Supply Voltage Minimum Supply Voltage vs Large Input Voltage
50 400 5 VS = 5V, 0V TA = 125°C 300 45 4 200 40 TA = 25°C 100 3 (V) 35 TA = –55°C 0 TA = 125°C TA = –55°C V OUT 5V –100 2 30 VIN + SUPPLY CURRENT (µA) –200 TA = 25°C 1 – 25 INPUT OFFSET VOLTAGE CHANGE (µV) –300 20 –400 0 2 4 6 8 10 12 14 16 18 0 1 2 3 4 5 –10–8 –6 –4 –2 0 2 4 6 8 10 12 14 16 18 SUPPLY VOLTAGE (V) TOTAL SUPPLY VOLTAGE (V) VIN (V) 1782 G01 1782 G02 1782 G03
Input Bias Current Output Saturation Voltage Output Saturation Voltage vs Common Mode Voltage vs Load Current (Output High) vs Load Current (Output Low)
6000 1 1 VS = 5V, 0V V V 5000 S = ±2.5V S = ±2.5V VOD = 30mV VOD = 30mV 4000 TA = 125°C 3000 T 2000 0.1 A = 125°C 1000 TA = 25°C TA = 125°C 0.1 T T A = –55°C 40 A = 25°C TA = –55°C TA = 25°C 30 TA = –55°C 0.01 INPUT BIAS CURRENT (nA) 20 10 OUTPUT SATURATION VOLTAGE (V) OUTPUT SATURATION VOLTAGE (V) 0 –10 0.01 0.001 3.8 4 4.2 4.4 4.6 4.8 5 5.2 5.4 15 16 18 1µ 10µ 100µ 1m 10m 1µ 10µ 1µ 1m 10m COMMON MODE VOLTAGE (V) SOURCING LOAD CURRENT (A) SINKING LOAD CURRENT (A) 1782 G04 1782 G05 1782 G06
Output Saturation Voltage Output Short-Circuit Current vs Input Overdrive vs Temperature 0.1Hz to 10Hz Noise Voltage
100 40 VS = ±5V VS = ±2.5V OUTPUT HIGH 35 SINKING CURRENT 30 10 SOURCING CURRENT 25 OUTPUT LOW OUTPUT CURRENT (mA) 20 NOISE VOLTAGE (400nV/DIV) OUTPUT SATURATION VOLTAGE (mV) VS = ±2.5V 1 NO LOAD 15 0 10 20 30 40 50 60 –50 –25 0 25 50 75 100 125 0 1 2 3 4 5 6 7 8 9 10 INPUT OVERDRIVE (mV) TEMPERATURE (°C) TIME (sec) 1782 G07 1782 G08 1782 G09 1782fc 8 Document Outline Features Description Applications Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Applications Information Simplified Schematic Typical Applications Package Description Revision History Typical Application Related Parts
