Datasheet LT1498, LT1499 (Analog Devices)
Description10MHz, 6V/µs, Dual/Quad Rail-to-Rail Input and Output Precision C-Load Op Amps
Pages / Page24 / 1 — FEATURES. DESCRIPTION. Rail-to-Rail Input and Output. 475μV Max VOS from …
File Format / SizePDF / 293 Kb
FEATURES. DESCRIPTION. Rail-to-Rail Input and Output. 475μV Max VOS from V+ to V–. Gain-Bandwidth Product: 10MHz
Datasheet LT1498, LT1499 Analog Devices
LT1498/LT1499 10MHz, 6V/µs, Dual/Quad Rail-to-Rail Input and Output Precision C-Load Op Amps
FEATURES DESCRIPTION
n
The LT®1498/LT1499 are dual/quad, rail-to-rail input and n
output precision C-Load™ op amps with a 10MHz gain- n
bandwidth product and a 6V/μs slew rate. n
Slew Rate: 6V/μs
The LT1498/LT1499 are designed to maximize input n
Low Supply Current per Amplifi er: 1.7mA
dynamic range by delivering precision performance over n Input Offset Current: 65nA Max the full supply voltage. Using a patented technique, both n Input Bias Current: 650nA Max input stages of the LT1498/LT1499 are trimmed, one at n Open-Loop Gain: 1000V/mV Min the negative supply and the other at the positive supply. n Low Input Noise Voltage: 12nV/√Hz Typ The resulting guaranteed common mode rejection is much n Wide Supply Range: 2.2V to ±15V better than other rail-to-rail input op amps. When used as n Large Output Drive Current: 30mA a unity-gain buffer in front of single supply 12-bit A-to-D n Stable for Capacitive Loads Up to 10,000pF converters, the LT1498/LT1499 are guaranteed to add less n Dual in 8-Pin PDIP and SO Package than 1LSB of error even in single 3V supply systems. n Quad in Narrow 14-Pin SO With 110dB of supply rejection, the LT1498/LT1499 main- tain their performance over a supply range of 2.2V to 36V
and are specifi ed for 3V, 5V and ±15V supplies. The inputs n Driving A-to-D Converters can be driven beyond the supplies without damage or phase n Active Filters reversal of the output. These op amps remain stable while n Rail-to-Rail Buffer Amplifi ers driving capacitive loads up to 10,000pF. n Low Voltage Signal Processing The LT1498 is available with the standard dual op amp n Battery-Powered Systems confi guration in 8-pin PDIP and SO packaging. The LT1499 L, LT, LTC, LTM, Linear Technology and the Linear logo are registered trademarks and C-Load features the standard quad op amp confi guration and is is a trademark of Linear Technology Corporation. All other trademarks are the property of their respective owners. available in a 14-pin plastic SO package. These devices can be used as plug-in replacements for many standard op amps to improve input/output range and precision.
TYPICAL APPLICATION Frequency Response
10 V 0 IN = 2.7VP-P V+ = 3V
Single Supply 100kHz 4th Order Butterworth Filter
–10 –20 –30 6.81k 100pF –40 6.81k 11.3k – 5.23k 47pF –50 VIN V+ 5.23k 10.2k – GAIN (dB) –60 330pF 1/2 LT1498 –70 + 1000pF 1/2 LT1498 V –80 OUT + –90 –100 V+/2 1498 TA01 –110100 1k 10k 100k 1M 10M FREQUENCY (Hz) 1498 TA02 14989fg 1
