Datasheet LT1354 (Analog Devices) - 6
Description12MHz, 400V/µs Op Amp
Pages / Page12 / 6 — TYPICAL PERFORMANCE CHARACTERISTICS. Output Voltage Swing vs. Open-Loop …
File Format / SizePDF / 266 Kb
TYPICAL PERFORMANCE CHARACTERISTICS. Output Voltage Swing vs. Open-Loop Gain vs Temperature. Supply Voltage. Load Current
TYPICAL PERFORMANCE CHARACTERISTICS Output Voltage Swing vs Open-Loop Gain vs Temperature Supply Voltage Load Current
LT1354
W U TYPICAL PERFORMANCE CHARACTERISTICS Output Voltage Swing vs Output Voltage Swing vs Open-Loop Gain vs Temperature Supply Voltage Load Current
97 V + V +– 0.5 R 85°C L = 1k TA = 25°C R VS = ±5V 96 L = 1k –1.0 VO = ±12V –1 VIN = 100mV VS = ±15V –1.5 – 40°C 95 –2 –2.0 94 RL = 500Ω –2.5 25°C 93 –3 92 85°C 3 2.5 91 RL = 500Ω 2.0 25°C OPEN-LOOP GAIN (dB) 2 90 – 40°C OUTPUT VOLTAGE SWING (V) OUTPUT VOLTAGE SWING (V) 1.5 1 89 RL = 1k 1.0 88 V – V–+0.5 – 50 –25 0 25 50 75 100 125 0 5 10 15 20 – 50 – 40 –30 –20 –10 0 10 20 30 40 50 TEMPERATURE (°C) SUPPLY VOLTAGE (±V) OUTPUT CURRENT (mA) 1354 G07 1354 G08 1354 G09
Output Short-Circuit Current vs Settling Time vs Output Step Settling Time vs Output Step Temperature (Noninverting) (Inverting)
65 10 10 VS = ±5V VS = ±15V VS = ±15V 60 8 8 AV = 1 AV = –1 55 6 6 4 10mV 4 10mV 50 1mV 2 2 1mV 45 SINK 0 0 40 –2 –2 SOURCE 35 1mV OUTPUT SWING (V) –4 OUTPUT SWING (V) –4 10mV 30 1mV –6 –6 10mV 25 OUTPUT SHORT-CIRCUIT CURRENT (mA) –8 –8 20 –10 –10 – 50 –25 0 25 50 75 100 125 50 100 150 200 250 300 350 50 100 150 200 250 300 350 TEMPERATURE (°C) SETTLING TIME (ns) SETTLING TIME (ns) 1354 G10 1354 G11 1355/1356 G12
Gain-Bandwidth and Phase Output Impedance vs Frequency Gain and Phase vs Frequency Margin vs Supply Voltage
1k 70 120 18 50 VS = ±15V 17 48 TA = 25°C 60 PHASE 100 PHASE MARGIN AV = 100 ) 100 PHASE (DEG) 16 46 50 V PHASE MARGIN (DEG) S = ±15V 80 Ω 15 44 VS = ±15V 40 60 10 14 42 GAIN 30 A V 40 13 40 S = ±5V V = 10 GAIN (dB) 1 12 38 20 20 VS = ±5V AV = 1 11 36 GAIN-BANDWIDTH OUTPUT IMPEDANCE ( 10 0 GAIN-BANDWIDTH (MHz) 0.1 T 10 34 A = 25°C 0 AV = –1 9 T 32 R A = 25°C F = RG = 2k 0.01 –10 8 30 10k 100k 1M 10M 100M 10k 100k 1M 10M 100M 0 5 10 15 20 FREQUENCY (Hz) FREQUENCY (Hz) SUPPLY VOLTAGE (±V) 1354 G13 1354 G14 1354 G15 6
