Datasheet LT1413 (Analog Devices)
DescriptionSingle Supply, Dual Precision Op Amp
Pages / Page8 / 1 — FEATU. DESCRIPTIO. Single Supply Operation:. At 5V, 0V Low Cost Grade …
File Format / SizePDF / 254 Kb
FEATU. DESCRIPTIO. Single Supply Operation:. At 5V, 0V Low Cost Grade Specifications:. APPLICATI. TYPICAL APPLICATI
Datasheet LT1413 Analog Devices
LT1413 Single Supply, Dual Precision Op Amp
U FEATU S RE DESCRIPTIO Single Supply Operation:
The LT1413 is a low cost, upgraded version of Linear ■ Input Goes Below Ground Technology’s industry standard LT1013 dual, single sup- ■ Output Swings to Ground Sinking Current ply op amp. The LT1413 is optimized for single 5V appli- ■ No Pull-Down Resistors Needed cations, although ±15V specifications are also provided ■ Phase Reversal Protection for completeness.
In the design of the LT1413, particular emphasis has been ■ 280µV Max Offset Voltage placed on low cost plastic and SO-8 package performance: ■ 380µV Max in S8 Package 60µV offset voltage, 0.1nA offset current, in excess of ■ 0.8nA Max Offset Current 10mA output current at 330µA supply current and 140dB ■ 480µA Max Supply Current per Amplifier channel separation are some of the specifications achieved. ■ 0.5µV/°C Drift ■ 1.4 Million Voltage Gain Other dual, single supply amplifiers are available to ■ 950kHz Gain-Bandwidth Product complement the LT1413 family: the micropower LT1078’s ■ 0.55µV supply current is 10 times lower with a 4.5 fold speed P-P, 0.1Hz to 10Hz Noise performance degradation compared to the LT1413. Con-
O U
versely, the LT1211, LT1213 and LT1215 duals have 4 to
APPLICATI S
14 times higher supply current, but also 13 to 50 times ■ higher speed. Single Supply Systems ■ Protected by U.S. Patent 4,775,884. Two and Three Op Amp Instrumentation Amplifiers ■ Active Filters ■ Battery-Powered Systems ■ Strain Gauge and Bridge Amplifiers
O U TYPICAL APPLICATI +90V, –3V Common-Mode Range Distribution of Input Offset Voltage Difference Amplifier (AV = 1) (In Plastic DIP, N8 Package)
30 10M VS = 5V, 0V T 25 A = 25°C 9V 10M 2 8 20 – – 1 OUTPUT INPUT 1/2 LT1413 10M 1M 20mV TO 8V 3 15 + + 4 1M PERCENT OF UNITS 10 10M 5 1.5mV OUTPUT OFFSET = (THE 0.1nA TYPICAL OFFSET CURRENT 0 125 (INPUT REFERRED = µV) PERMITS THE USE OF 1MΩ RESISTORS) –300 –200 –100 0 100 200 300 11M INPUT RESISTANCE = INPUT OFFSET VOLTAGE (µV) 80kHz BANDWIDTH = LT1413 • TA03 LT1413 • TA01 1
