Datasheet LT1413 (Analog Devices) - 6
DescriptionSingle Supply, Dual Precision Op Amp
Pages / Page8 / 6 — TYPICAL PERFOR A CE CHAR C. A TERISTICS. Channel Separation vs. Voltage …
File Format / SizePDF / 254 Kb
TYPICAL PERFOR A CE CHAR C. A TERISTICS. Channel Separation vs. Voltage Gain vs Frequency. Gain, Phase vs Frequency. Frequency
TYPICAL PERFOR A CE CHAR C A TERISTICS Channel Separation vs Voltage Gain vs Frequency Gain, Phase vs Frequency Frequency
LT1413
W U TYPICAL PERFOR A CE CHAR C A TERISTICS Channel Separation vs Voltage Gain vs Frequency Gain, Phase vs Frequency Frequency
140 80 160 TA = 25°C TA = 25°C TA = 25°C 120 C 20 100 L = 100pF VCM = 0.1V VS = 5V, 0V PHASE CL = 100pF PHASE SHIFT (DEGREES) 140 VIN = 3Vp-p 100 120 RL = 2k ±15V 80 10 140 120 LIMITED BY GAIN ±15V THERMAL RS = 100Ω 60 160 INTERACTION VS = ±15V R 40 0 180 100 S = 1kΩ 5V, 0V 5V, 0V VOLTAGE GAIN (dB) VS = 5V, 0V VOLTAGE GAIN (dB) 20 200 CHANNEL SEPARATION (dB) 80 LIMITED BY 0 –10 PIN TO PIN CAPACITANCE – 20 60 0.01 0.1 1 10 100 1k 10k 100k 1M 10M 0.1 0.3 1 3 10 10 100 1k 10k 100k 1M FREQUENCY (Hz) FREQUENCY (MHz) FREQUENCY (Hz) LT1413 • TA12 LT1413 • TA13 LT1413 • TA14
Common-Mode Rejection Ratio Power Supply Rejection Ratio Small Signal Transient vs Frequency vs Frequency Response, VS =
15V
120 120 TA = 25°C TA = 25°C VS = 5V, 0V 100 100 V NEGATIVE POSITIVE S = ± 15V 80 80 SUPPLY SUPPLY ±15V ±15V V 20mV/DIV S = 5V, 0V 60 60 40 40 20 20 AV = +1 2µs/DIV COMMON-MODE REJECTION RATIO (dB) POWER SUPPLY REJECTION RATIO (dB) 0 0 LT1413 • TA17 10 100 1k 10k 100k 1M 0.1 1 10 100 1k 10k 100k 1M FREQUENCY (Hz) FREQUENCY (Hz) LT1413 • TA15 LT1413 • TA16
Small Signal Transient Large Signal Transient Large Signal Transient Response, VS = 5V, 0V Response, VS = 5V, 0V Response, VS =
15V
4V 2V 5V/DIV 50mV/DIV 0V 0V A 20µs/DIV A 10 V = +1 µs/DIV A V = +1 V = +1 50µs/DIV INPUT = 20mV TO 220mV PULSE NO LOAD LT1413 • TA18 INPUT = 0V TO 4V PULSE LT1413 • TA19 LT1413 • TA20 6
