Datasheet LT1113 (Analog Devices) - 6
DescriptionDual Low Noise, Precision, JFET Input Op Amps
Pages / Page18 / 6 — elecTrical characTerisTics Note 7:. Note 11:. Note 8:. Note 9:. Note 12:. …
File Format / SizePDF / 721 Kb
elecTrical characTerisTics Note 7:. Note 11:. Note 8:. Note 9:. Note 12:. Note 10:. Typical perForMance characTerisTics
elecTrical characTerisTics Note 7: Note 11: Note 8: Note 9: Note 12: Note 10: Typical perForMance characTerisTics
LT1113
Input voltage range functionality is assured by testing offset
Note 11:
∆CMRR and ∆PSRR are defined as follows: voltage at the input voltage range limits to a maximum of 2.3mV (1) CMRR and PSRR are measured in µV/V on the individual amplifiers. (A grade) to 2.8mV (C grade). (2) The difference is calculated between the matching sides in µV/V.
Note 8:
This parameter is not 100% tested. (3) The result is converted to dB.
Note 9:
Slew rate is measured in AV = –1; input signal is ±7.5V, output
Note 12:
The LT1113 is measured in an automated tester in less than one measured at ±2.5V. second after application of power. Depending on the package used, power
Note 10:
The LT1113 is designed, characterized and expected to meet dissipation, heat sinking, and air flow conditions, the fully warmed-up chip these extended temperature limits, but is not tested at –40°C and 85°C. temperature can be 10°C to 50°C higher than the ambient temperature. Guaranteed I grade parts are available. Consult factory.
Typical perForMance characTerisTics 1kHz Output Voltage Noise 0.1Hz to 10Hz Voltage Noise Density vs Source Resistance Voltage Noise vs Frequency
) 10k 100 Hz ) TA = 25°C + Hz VS = ±15V VN 1k – RSOURCE 100 10 TYPICAL VOLTAGE NOISE (1µV/DIV) 10 VN 1/f CORNER SOURCE T 120Hz A = 25°C RESISTANCE VS = ±15V RMS VOLTAGE NOISE DENSITY (nV/√ ONLY TOTAL 1kHz VOLTAGE NOISE DENSITY (nV/√ 1 1 0 2 4 6 8 10 100 1k 10k 100k 1M 10M 100M 1G 1 10 100 1k 10k TIME (SEC) SOURCE RESISTANCE (Ω) FREQUENCY (Hz) 1113 G01 1113 G02 1113 G03
Voltage Noise vs Input Bias and Offset Currents vs Input Bias and Offset Currents Chip Temperature Chip Temperature Over the Common Mode Range
10 100n 400 9 VS = ±15V 30n VS = ±15V TA = 25°C ) V Hz S = ±15V 8 10n NOT WARMED UP 300 7 3n IB, VCM = 0V 6 1n IB, VCM = 10V 5 300p 200 4 100p BIAS CURRENT 3 30p I 100 2 10p OS, VCM = 0V VOLTAGE NOISE (AT1kHz)(nV/√ I 1 3p OS, VCM = 10V INPUT BIAS AND OFFSET CURRENTS (A) INPUT BIAS AND OFFSET CURRENTS (pA) OFFSET CURRENT 0 1p 0 –75 –50 –25 0 25 50 75 100 125 –75 –50 –25 0 25 50 75 100 125 –15 –10 –5 0 5 10 15 TEMPERATURE (°C) TEMPERATURE (°C) COMMON MODE RANGE (V) 1113 G04 1113 G05 1113 G06 1113fc 6 For more information www.linear.com/LT1113
