Datasheet LT1213, LT1214 (Analog Devices) - 4
Description28MHz, 12V/µs, Single Supply Quad Precision Op Amps
Pages / Page20 / 4 — 5V ELECTRICAL CH. ARA TERISTICS. VS = 5V, VCM = 0.5V, VOUT = 0.5V, 0. C, …
File Format / SizePDF / 401 Kb
5V ELECTRICAL CH. ARA TERISTICS. VS = 5V, VCM = 0.5V, VOUT = 0.5V, 0. C, unless otherwise noted. LT1213AC. LT1213C/LT1214C
5V ELECTRICAL CH ARA TERISTICS VS = 5V, VCM = 0.5V, VOUT = 0.5V, 0 C, unless otherwise noted LT1213AC LT1213C/LT1214C
LT1213/LT1214
5V ELECTRICAL CH C ARA TERISTICS VS = 5V, VCM = 0.5V, VOUT = 0.5V, 0
C
TA
70
C, unless otherwise noted. LT1213AC LT1213C/LT1214C SYMBOL PARAMETER CONDITIONS MIN TYP MAX MIN TYP MAX UNITS
VOS Input Offset Voltage 100 175 150 375 µV ∆VOS Input Offset Voltage Drift 8-Pin DIP Package 0.7 1.5 1 3 µV/°C ∆T (Note 4) 14-Pin DIP, SOIC Package 2 6 µV/°C IOS Input Offset Current 10 45 10 55 nA IB Input Bias Current 90 190 110 230 nA Input Voltage Range 3.4 3.5 3.4 3.5 V 0.1 – 0.1 0.1 – 0.1 V CMRR Common Mode Rejection Ratio VCM = 0.1V to 3.4V 89 105 85 105 dB PSRR Power Supply Rejection Ratio VS = 2.5V to 12.5V 92 114 89 114 dB AVOL Large-Signal Voltage Gain VO = 0.05V to 3.7V, RL = 500Ω 200 580 200 580 V/mV Maximum Output Voltage Swing Output High, No Load 4.20 4.33 4.20 4.33 V (Note 5) Output High, ISOURCE = 1mA 4.10 4.25 4.10 4.25 V Output High, ISOURCE = 15mA 3.84 3.96 3.84 3.96 V Output Low, No Load 0.005 0.008 0.005 0.008 V Output Low, ISINK = 1mA 0.036 0.055 0.036 0.055 V Output Low, ISINK = 15mA 0.370 0.530 0.370 0.530 V IS Supply Current per Amplifier 1.8 2.9 4.0 1.8 2.9 4.0 mA
VS = 5V, VCM = 0.5V, VOUT = 0.5V, – 40
C
TA
85
C, unless otherwise noted. (Note 6) LT1213AC LT1213C/LT1214C SYMBOL PARAMETER CONDITIONS MIN TYP MAX MIN TYP MAX UNITS
VOS Input Offset Voltage 120 200 175 500 µV ∆VOS Input Offset Voltage Drift 8-Pin DIP Package 0.7 1.5 1 3 µV/°C ∆T (Note 4) 14-Pin DIP, SOIC Package 2 6 µV/°C IOS Input Offset Current 15 50 20 75 nA IB Input Bias Current 100 200 120 250 nA Input Voltage Range 3.1 3.2 3.1 3.2 V 0.2 0 0.2 0 V CMRR Common Mode Rejection Ratio VCM = 0.2V to 3.1V 88 104 84 104 dB PSRR Power Supply Rejection Ratio VS = 2.5V to 12.5V 91 113 88 113 dB AVOL Large-Signal Voltage Gain VO = 0.05V to 3.7V, RL = 500Ω 200 510 200 510 V/mV Maximum Output Voltage Swing Output High, No Load 4.15 4.25 4.15 4.25 V (Note 5) Output High, ISOURCE = 1mA 4.00 4.16 4.00 4.16 V Output High, ISOURCE = 15mA 3.72 3.89 3.72 3.89 V Output Low, No Load 0.006 0.009 0.006 0.009 V Output Low, ISINK = 1mA 0.037 0.060 0.037 0.060 V Output Low, ISINK = 15mA 0.380 0.550 0.380 0.550 V IS Supply Current per Amplifier 1.5 2.9 4.0 1.5 2.9 4.0 mA 4
