Datasheet LT1213, LT1214 (Analog Devices) - 5
Description | 28MHz, 12V/µs, Single Supply Quad Precision Op Amps |
Pages / Page | 20 / 5 — 5V ELECTRICAL CH. ARA TERISTICS. VS = 5V, VCM = 0.5V, VOUT = 0.5V, – 55. … |
File Format / Size | PDF / 401 Kb |
5V ELECTRICAL CH. ARA TERISTICS. VS = 5V, VCM = 0.5V, VOUT = 0.5V, – 55. 125. C, unless otherwise noted. LT1213AM. LT1213M
LT1213/LT1214
5V ELECTRICAL CH C ARA TERISTICS VS = 5V, VCM = 0.5V, VOUT = 0.5V, – 55
C
TA
125
C, unless otherwise noted. LT1213AM LT1213M SYMBOL PARAMETER CONDITIONS MIN TYP MAX MIN TYP MAX UNITS
VOS Input Offset Voltage 140 250 200 500 µV ∆VOS Input Offset Voltage Drift 0.7 1.5 1.0 3.0 µV/°C ∆T (Note 4) IOS Input Offset Current 20 70 25 100 nA IB Input Bias Current 105 210 125 275 nA Input Voltage Range 3.1 3.2 3.1 3.2 V 0.4 0.2 0.4 0.2 V CMRR Common Mode Rejection Ratio VCM = 0.4V to 3.1V 87 104 83 104 dB PSRR Power Supply Rejection Ratio VS = 2.5V to 12.5V 90 113 87 113 dB AVOL Large-Signal Voltage Gain VO = 0.05V to 3.7V, RL = 500Ω 150 300 150 300 V/mV Maximum Output Voltage Swing Output High, No Load 4.05 4.20 4.05 4.20 V (Note 5) Output High, ISOURCE = 1mA 3.90 4.10 3.90 4.10 V Output High, ISOURCE = 15mA 3.60 3.80 3.60 3.80 V Output Low, No Load 0.007 0.012 0.007 0.012 mV Output Low, ISINK = 1mA 0.040 0.070 0.040 0.070 mV Output Low, ISINK = 15mA 0.400 0.750 0.400 0.750 mV IS Supply Current per Amplifier 1.3 3.0 4.2 1.3 3.0 4.2 mA
+15V ELECTRICAL CH C ARA TERISTICS – VS =
15V, VCM = 0V, VOUT = 0V, TA = 25
C, unless otherwise noted. LT1213AC LT1213C/LT1213M LT1213AM LT1214C SYMBOL PARAMETER CONDITIONS MIN TYP MAX MIN TYP MAX UNITS
VOS Input Offset Voltage 125 400 150 550 µV IOS Input Offset Current 5 30 5 40 nA IB Input Bias Current 70 150 90 190 nA Input Voltage Range 13.5 13.8 13.5 13.8 V –15.0 – 15.3 –15.0 – 15.3 V CMRR Common Mode Rejection Ratio VCM = –15V to 13.5V 90 107 86 107 dB PSRR Power Supply Rejection Ratio VS = ±2V to ±18V 93 116 90 116 dB AVOL Large-Signal Voltage Gain VO = 0V to ±10V, RL = 2k 1200 4000 1200 4000 V/mV Maximum Output Voltage Swing Output High, ISOURCE = 20mA 13.7 13.9 13.7 13.9 V Output Low, ISINK = 20mA –14.3 –14.5 –14.3 –14.5 V IO Maximum Output Current (Note 10) ±30 ±50 ±30 ±50 mA SR Slew Rate AV = – 2 (Note 7) 10 12 10 12 V/µs GBW Gain-Bandwidth Product f = 100kHz 15 28 15 28 MHz IS Supply Current per Amplifier 2.0 3.4 4.7 2.0 3.4 4.7 mA Channel Separation VO = ±10V, RL = 2k 128 140 128 140 dB Minimum Supply Voltage Equal Split Supplies ±1.2 ±2.0 ±1.2 ±2.0 V Full-Power Bandwidth AV = 1, VO = 20VP-P 150 150 kHz Settling Time 0.01%, AV = 1, ∆VO = 10V 1.1 1.1 µs 5
