Datasheet LT1124, LT1125 (Analog Devices) - 9
Description | Dual/Quad Low Noise, High Speed Precision Op Amps |
Pages / Page | 20 / 9 — Typical perForMance characTerisTics. Total Harmonic Distortion. and Noise … |
File Format / Size | PDF / 383 Kb |
Typical perForMance characTerisTics. Total Harmonic Distortion. and Noise vs Frequency for. Noninverting Gain. Inverting Gain
LT1124/LT1125
Typical perForMance characTerisTics Total Harmonic Distortion Total Harmonic Distortion Total Harmonic Distortion and Noise vs Frequency for and Noise vs Frequency for and Noise vs Frequency for Noninverting Gain Inverting Gain Competitive Devices
0.1 0.1 0.1 ZL = 2k/15pF ZL = 2k/15pF ZL = 2k/15pF VO = 20VP-P VO = 20Vp-p VO = 20Vp-p AV = +1, +10, +100 AV = –1, –10, –100 AV = –10 MEASUREMENT BANDWIDTH MEASUREMENT BANDWIDTH MEASUREMENT BANDWIDTH = 10Hz TO 80kHz = 10Hz TO 80kHz = 10Hz TO 80kHz 0.010 0.010 0.010 TION + NOISE (%) TION + NOISE (%) TION + NOISE (%) AV = +100 AV = –100 OP270 AV = +10 AV = –10 OP27 0.001 0.001 0.001 AV = +1 LT1124 AV = –1 AL HARMONIC DISTOR AL HARMONIC DISTOR AL HARMONIC DISTOR TOT TOT TOT 0.0001 0.0001 0.0001 20 100 1k 10k 20k 20 100 1k 10k 20k 20 100 1k 10k 20k FREQUENCY (Hz) FREQUENCY (Hz) FREQUENCY (Hz) 1124/25 G22 1124/25 G23 1124/25 G24
Total Harmonic Distortion and Total Harmonic Distortion and Intermodulation Distortion Noise vs Output Amplitude for Noise vs Output Amplitude for (CCIF Method)* vs Frequency Noninverting Gain Inverting Gain LT1124 and OP270
1 1 0.010 ZL = 2k/15pF ZL = 2k/15pF ZL = 2k/15pF fO = 1kHz fO = 1kHz f (IM) = 1kHz AV = +1, +10, +100 AV = –1, –10, –100 fO = 13.5kHz 0.1 MEASUREMENT BANDWIDTH 0.1 MEASUREMENT BANDWIDTH VO = 20Vp-p = 10Hz TO 22kHz = 10Hz TO 22kHz A TION (IMD)(%) V = –10 MEASUREMENT BANDWIDTH TION + NOISE (%) TION + NOISE (%) A = 10Hz TO 80kHz V = +100 OP270 0.010 0.010 AV = –100 0.001 AV = +10 AV = –10 TION DISTOR 0.001 0.001 A A LT1124 V = +1 V = –1 AL HARMONIC DISTOR AL HARMONIC DISTOR TOT TOT INTERMODULA 0.0001 0.0001 0.0001 0.3 1 10 30 0.3 1 10 30 3k 10k 20k OUTPUT SWING (VP-P) OUTPUT SWING (Vp-p) FREQUENCY (Hz) 1124/25 G25 1124/25 G26 1124/25 G27 11245ff For more information www.linear.com/LT1124 9 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Applications Information Performance Comparison Typical Applications Schematic Diagram Package Description Revision History Typical Application Related Parts
