Datasheet LT1006 (Analog Devices) - 2
DescriptionPrecision, Single Supply Op Amp
Pages / Page16 / 2 — ABSOLUTE AXI U RATI GS (Note 1). (OBSOLETE). PACKAGE/ORDER I FOR ATIO. …
File Format / SizePDF / 304 Kb
ABSOLUTE AXI U RATI GS (Note 1). (OBSOLETE). PACKAGE/ORDER I FOR ATIO. OBSOLETE PACKAGES
ABSOLUTE AXI U RATI GS (Note 1) (OBSOLETE) PACKAGE/ORDER I FOR ATIO OBSOLETE PACKAGES
LT1006
W W W U ABSOLUTE AXI U RATI GS (Note 1)
Supply Voltage .. ±22V Operating Temperature Range Input Voltage ... Equal to Positive Supply Voltage LT1006AM/LT1006M
(OBSOLETE)
..– 55°C to 125°C Input Voltage .. 5V Below Negative Supply Voltage LT1006AC/LT1006C/LT1006S8 ... 0°C to 70°C Differential Input Voltage ... 30V Storage Temperature Range ... – 65°C to 150°C Output Short-Circuit Duration .. Indefinite Lead Temperature (Soldering, 10 sec).. 300°C
U W U PACKAGE/ORDER I FOR ATIO
ORDER TOP VIEW ORDER TOP VIEW PART NUMBER VOS I 1 8 SY SET PART NUMBER TRIM – (NOTE 3) ISY SET (NOTE 3) LT1006AMH –IN 2 7 V+ LT1006CN8 + 8 V LT1006MH +IN 3 6 OUT LT1006S8 OS 1 7 V+ VOS TRIM TRIM LT1006ACH V– 4 5 (NOTE 4) – –IN 2 6 OUT S8 PART MARKING + LT1006CH N8 PACKAGE S8 PACKAGE 8-LEAD PDIP 8-LEAD PLASTIC SO +IN 3 5 V 1006 OS TJMAX = 100°C, θJA = 130°C/W (N8) 4 TRIM TJMAX = 150°C, θJA = 200°C/W (S8) (NOTE 4) V– (CASE) J8 PACKAGE 8-LEAD CERDIP LT1006AMJ8 H PACKAGE T 8-LEAD TO-5 METAL CAN JMAX = 100°C, θJA = 130°C/W LT1006MJ8 TJMAX = 150°C, θJA = 150°C, θJC = 45°C LT1006ACJ8 LT1006CJ8
OBSOLETE PACKAGES
Consider the N8 or S8 Package for Alternate Source Consult LTC Marketing for parts specified with wider operating temperature ranges.
ELECTRICAL CHARACTERISTICS VS = 5V, VCM = 0V, VOUT = 1.4V, TA = 25
C, unless otherwise noted. LT1006AM/AC LT1006M/C SYMBOL PARAMETER CONDITIONS MIN TYP MAX MIN TYP MAX UNITS
VOS Input Offset Voltage 20 50 30 80 µV LT1006S8 80 400 µV ∆VOS Long-Term Input Offset 0.4 0.5 µV/Mo ∆Time Voltage Stability LT1006S8 0.7 µV/Mo IOS Input Offset Current 0.12 0.5 0.15 0.9 nA IB Input Bias Current 9 15 10 25 nA en Input Noise Voltage 0.1Hz to 10Hz 0.55 0.55 µVP-P Input Noise Voltage Density fO = 10Hz 23 32 23 32 nV/√Hz fO = 1000Hz 22 25 22 25 nV/√Hz in Input Noise Current Density fO = 10Hz 0.07 0.08 pA/√Hz Input Resistance (Note 2) Differential Mode 180 400 100 300 MΩ Common Mode 5 4 GΩ 1006fa 2
