Datasheet LT1006 (Analog Devices) - 3
DescriptionPrecision, Single Supply Op Amp
Pages / Page16 / 3 — ELECTRICAL CHARACTERISTICS VS = 5V, VCM = 0V, VOUT = 1.4V, TA = 25. C, …
File Format / SizePDF / 304 Kb
ELECTRICAL CHARACTERISTICS VS = 5V, VCM = 0V, VOUT = 1.4V, TA = 25. C, unless otherwise noted. LT1006AM/AC. LT1006M/C. SYMBOL
ELECTRICAL CHARACTERISTICS VS = 5V, VCM = 0V, VOUT = 1.4V, TA = 25 C, unless otherwise noted LT1006AM/AC LT1006M/C SYMBOL
LT1006
C, unless otherwise noted. LT1006AM/AC LT1006M/C SYMBOL PARAMETER CONDITIONS MIN TYP MAX MIN TYP MAX UNITS
Input Voltage Range 3.5 3.8 3.5 3.8 V 0 – 0.3 0 – 0.3 V CMRR Common Mode Rejection Ratio VCM = 0V to 3.5V 100 114 97 112 dB PSRR Power Supply Rejection Ratio VS = ±2V to ±18V, VO = 0V 106 126 103 124 dB AVOL Large-Signal Voltage Gain VO = 0.03V to 4V, RL = 10k 1.0 2.5 0.7 2.0 V/µV VO = 0.03V to 3.5V, RL = 2k 0.5 2.0 0.3 1.8 V/µV Maximum Output Voltage Swing Output Low, No Load 15 25 15 25 mV Output Low, 600Ω to GND 5 10 5 10 mV Output Low, ISINK = 1mA 220 350 220 350 mV Output High, No Load 4.0 4.4 4.0 4.4 V Output High, 600Ω to GND 3.4 4.0 3.4 4.0 V SR Slew Rate 0.25 0.4 0.25 0.4 V/µs IS Supply Current RSET = ∞ 340 520 350 570 µA RSET = 180k Pin 8 to Pin 7 (Note 3) 90 90 µA Minimum Supply Voltage 2.7 2.7 V
The
denotes the specifications which apply over the full operating temperature range. VS = 5V, 0V; VCM = 0.1V; VO = 1.4V; –55
C
TA
125
C, unless otherwise noted. LT1006AM LT1006M SYMBOL PARAMETER CONDITIONS MIN TYP MAX MIN TYP MAX UNITS
VOS Input Offset Voltage ● 40 180 60 250 µV ∆VOS Input Offset Voltage Drift ● 0.2 1.3 0.3 1.8 µV/°C ∆Temp IOS Input Offset Current ● 0.4 2.0 0.5 4.0 nA IB Input Bias Current ● 13 25 16 40 nA AVOL Large-Signal Voltage Gain VO = 0.05V to 3.5V, RL = 2k ● 0.25 0.8 0.15 0.7 V/µV CMRR Common Mode Rejection Ratio VCM = 0.1V to 3.2V ● 90 103 87 102 dB PSRR Power Supply Rejection Ratio VS = ±2V to ±18V, VO = 0V ● 100 117 97 116 dB Maximum Output Voltage Swing Output Low, 600Ω to GND ● 6 15 6 18 mV Output High, 600Ω to GND ● 3.2 3.8 3.1 3.8 V IS Supply Current ● 380 630 400 680 µA 1006fa 3
