Datasheet LT1013, LT1014 (Analog Devices) - 2
DescriptionDual/Quad Precision Op Amps
Pages / Page26 / 2 — absoluTe MaxiMuM raTings (Note 1). pin conFiguraTion. OBSOLETE PACKAGE
File Format / SizePDF / 573 Kb
absoluTe MaxiMuM raTings (Note 1) pin conFiguraTion OBSOLETE PACKAGE
LT1013/LT1014
Supply Voltage ... ±22V Lead Temperature (Soldering, 10 sec.) ... 300°C Differential Input Voltage.. ±30V Operating Temperature Range Input Voltage .. Equal to Positive Supply Voltage LT1013AM/LT1013M/ ..5V Below Negative Supply Voltage LT1014AM/LT1014M ...– 55 °C to 125°C Output Short-Circuit Duration .. Indefinite LT1013AC/LT1013C/LT1013D Storage Temperature Range LT1014AC/LT1014C/LT1014D... 0°C to 70°C All Grades ..–65°C to 150°C LT1013I/ LT1014I ...– 40°C to 85°C
pin conFiguraTion
LT1013 LT1013 LT1013 TOP VIEW TOP VIEW TOP VIEW V+ – OUTPUT A 1 V+ +INA 1 8 –INA 8 8 + –IN A 2 – OUTPUT B OUTPUT A 1 7 OUTPUT B V– 7 2 7 OUTA +A A B +IN A 3 – 6 –IN B +INB 3 + 6 V+ B + –IN A 2 – + + – 6 –IN B V– 4 5 +IN B –INB 4 – 5 OUTB +IN A 3 5 +IN B 4 S8 PACKAGE N8 PACKAGE 8-LEAD PLASTIC SO 8-LEAD PDIP V–(CASE) TJMAX = 150°C, θJA = 130°C NOTE: THIS PIN CONFIGURATION DIFFERS FROM H PACKAGE J8 PACKAGE THE STANDARD 8-PIN DUAL-IN-LINE CONFIGURATION 8-LEAD TO-5 METAL CAN 8-LEAD CERDIP T TJMAX = 125°C, θJA = 55°C/W JMAX = 150°C, θJA = 190°C/W TJMAX = 150°C, θJA = 100°C
OBSOLETE PACKAGE OBSOLETE PACKAGE
Consider the N or S8 Packages for Alternate Source Consider the N or S8 (Not N8) Packages for Alternate Source LT1014 LT1014 TOP VIEW OUTPUT A 1 14 OUTPUT D TOP VIEW – – –IN A 2 13 –IN D OUTPUT A 1 16 OUTPUT D +A D + +IN A 3 12 +IN D –IN A 2 15 –IN D V+ 4 11 V– +IN A 3 14 +IN D +IN B 5 10 +IN C + + V+ 4 13 V– B C –IN B 6 – – 9 –IN C +IN B 5 12 +IN C OUTPUT B 7 8 OUTPUT C –IN B 6 11 –IN C OUTPUT B 7 10 OUTPUT C N PACKAGE 14-LEAD PDIP NC 8 9 NC TJMAX = 150°C, θJA = 100°C SW PACKAGE J PACKAGE 16-LEAD PLASTIC SO 14-LEAD CERDIP TJMAX = 150°C, θJA = 100°C TJMAX = 150°C, θJA = 130°C/W
OBSOLETE PACKAGE
Consider the N or SW Packages for Alternate Source 10134fe 2 For more information www.linear.com/LT1013 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Applications Information Typical Applications schematic diagram Package Description Revision History Typical Application Related Parts
