Datasheet LT1013, LT1014 (Analog Devices) - 6
DescriptionDual/Quad Precision Op Amps
Pages / Page26 / 6 — elecTrical characTerisTics. The. denotes the specifications which apply …
File Format / SizePDF / 573 Kb
elecTrical characTerisTics. The. denotes the specifications which apply over the temperature range
elecTrical characTerisTics The denotes the specifications which apply over the temperature range
LT1013/LT1014
denotes the specifications which apply over the temperature range –40°C ≤ TA ≤ 85°C for LT1013I, LT1014I, 0°C ≤ TA ≤ 70°C for LT1013C, LT1013D, LT1014C, LT1014D. VS = ±15V, VCM = 0V unless otherwise noted. LT1013C/D/I LT1013AC LT1014AC LT1014C/D/I SYMBOL PARAMETER CONDITIONS MIN TYP MAX MIN TYP MAX MIN TYP MAX UNITS
VOS Input Offset Voltage l 55 240 65 270 80 400 µV LT1013D/I, LT1014D/I l 230 1000 µV V 75 350 85 380 110 570 µV S = 5V, 0V; VO = 1.4V l LT1013D/I, LT1014D/I V l 280 1200 µV S = 5V, 0V; VO = 1.4V Average Input Offset (Note 3) l 0.3 2.0 0.3 2.0 0.4 2.5 µV/°C Voltage Drift LT1013D/I, LT1014D/I l 0.7 5.0 µV/°C IOS Input Offset Current l 0.2 1.5 0.2 1.7 0.3 2.8 nA VS = 5V, 0V; VO = 1.4V l 0.4 3.5 0.4 4.0 0.5 6.0 nA IB Input Bias Current l 13 25 13 25 16 38 nA VS = 5V, 0V; VO = 1.4V l 18 55 20 60 24 90 nA AVOL Large-Signal Voltage Gain VO = ±10V, RL = 2k l 1.0 5.0 1.0 5.0 0.7 4.0 V/µV CMRR Common Mode Rejection VCM = 13.0V, –15.0V l 98 116 98 116 94 113 dB Ratio PSRR Power Supply Rejection VS = ±2V to ±18V l 101 119 101 119 97 116 dB Ratio VOUT Output Voltage Swing RL = 2k l ±12.5 ±13.9 ±12.5 ±13.9 ±12.0 ±13.9 V VS = 5V, 0V; RL = 600Ω Output Low l 6 13 6 13 6 13 mV Output High l 3.3 3.9 3.3 3.9 3.2 3.9 V IS Supply Current per Amplifier l 0.36 0.55 0.36 0.55 0.37 0.60 mA VS = 5V, 0V; VO = 1.4V l 0.32 0.50 0.32 0.50 0.34 0.55 mA
Note 1:
Note 2:
This parameter is guaranteed by design and is not tested. Typical may cause permanent damage to the device. Exposure to any Absolute parameters are defined as the 60% yield of parameter distributions of Rating condition for extended periods may affect device reliability individual amplifiers; i.e., out of 100 LT1014s (or 100 LT1013s) typically and lifetime. 240 op amps (or 120 ) will be better than the indicated specification.
Note 3:
This parameter is not 100% tested. 10134fe 6 For more information www.linear.com/LT1013 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Applications Information Typical Applications schematic diagram Package Description Revision History Typical Application Related Parts
