Datasheet LTC2063, LTC2064 (Analog Devices) - 10
Description | 2µA Supply Current, Low IB, Dual Low Power Zero-Drift Operational Amplifiers |
Pages / Page | 30 / 10 — TYPICAL PERFORMANCE CHARACTERISTICS. Maximum Undistorted Output. THD vs … |
Revision | A |
File Format / Size | PDF / 2.0 Mb |
TYPICAL PERFORMANCE CHARACTERISTICS. Maximum Undistorted Output. THD vs Frequency. Amplitude vs Frequency
LTC2063/LTC2064
TYPICAL PERFORMANCE CHARACTERISTICS Maximum Undistorted Output THD vs Frequency Amplitude vs Frequency Supply Current vs Supply Voltage
) P-P 6 2.5 –20 RL=10kΩ AV = +1 RL=100kΩ V 125°C S = ±2.5V 5 TAGE (V RL=499kΩ V 2.0 OUT = ±2V 85°C –40 TION (dB) 4 1.5 25°C 3 –60 TED OUTPUT VOL –40°C 1.0 2 PER AMPLIFIER (µA) I S –80 R A 0.5 AL HARMONIC DISTOR L=499kΩ V = +1 1 R V L=100kΩ S = ±2.5V TOT R THD < –40dB L=10kΩ 0 0 –100 MAXIMUM UNDISTOR 20 100 1k 2k 0 0.5 1 1.5 2 2.5 3 3.5 4 4.5 5 5.5 20 100 500 FREQUENCY (Hz) VS (V) FREQUENCY (Hz) 2063 G34 2063 G35 2063 G33
Supply Current vs SHDN Pin Supply Current vs SHDN Pin Supply Current vs Temperature Voltage Voltage
2.2 10 3.0 VS = 5V V 9 S = 1.8V 2.0 2.5 8 1.8 7 125°C 2.0 VS = 5V 85°C 1.6 6 5 1.5 25°C 1.4 V 4 S = 1.8V 85°C 125°C –40°C PER AMPLIFIER (µA) 25°C 1.0 1.2 PER AMPLIFIER (µA) PER AMPLIFIER (µA) I S 3 I S I S 2 1.0 0.5 1 0.8 –40°C 0 0 –50 –25 0 25 50 75 100 125 0 0.5 1 1.5 2 2.5 3 3.5 4 4.5 5 0 0.2 0.4 0.6 0.8 1 1.2 1.4 1.6 1.8 TEMPERATURE (°C) SHDN PIN VOLTAGE (V) SHDN PIN VOLTAGE (V) 2063 G36 2063 G37 2063 G38
SHDN Pin Pull-Up Current vs SHDN Pin Pull-Up Current vs SHDN Pin Voltage SHDN Pin Voltage SHDN Pin Current vs Temperature
20 20 –30 VS = 5V 10 VS = 1.8V 10 VSHDN = 0V 0 0 –40 –10 –10 –20 –20 –30 –40°C –30 –50 –40°C (nA) –40 (nA) –40 (nA) 25°C 25°C I SHDN –50 I SHDN –50 I SHDN –60 –60 85°C –60 85°C –70 –70 125°C –80 –70 125°C –80 –90 –90 –100 –100 –80 –1 0 1 2 3 4 5 6 –1 –0.5 0 0.5 1 1.5 2 –50 –25 0 25 50 75 100 125 VSHDN (V) VSHDN (V) TEMPERATURE (°C) 2063 G39 2063 G40 2063 G41 Rev A 10 For more information www.analog.com Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Applications Information Typical Applications Package Description Revision History Typical Application Related Parts
