Datasheet LTC6258, LTC6259, LTC6260 (Analog Devices) - 8
Description1.3MHz, 20µA Power Efficient Rail-to-Rail I/O Op Amps
Pages / Page28 / 8 — TYPICAL PERFORMANCE CHARACTERISTICS. Input Bias Current. Supply Current …
TYPICAL PERFORMANCE CHARACTERISTICS. Input Bias Current. Supply Current vs Supply Voltage. vs Supply Voltage
TYPICAL PERFORMANCE CHARACTERISTICS Input Bias Current Supply Current vs Supply Voltage vs Supply Voltage
LTC6258/LTC6259/LTC6260
TYPICAL PERFORMANCE CHARACTERISTICS Input Bias Current Supply Current vs Supply Voltage vs Supply Voltage Input Bias Current vs Temperature per Channel
10 20 20 V V 8 S = ±2.5V CM = 0.4V +IB (nA) –IB (nA) 15 18 6 VS = 5V 16 10 VCM = 0.4V 4 14 2 5 12 0 0 10 –2 Y CURRENT (uA) –5 8 –4 +IB, V 6 CM = 2V SUPPL INPUT BIAS CURRENT (nA) –10 –6 INPUT BIAS CURRENT (nA) –IB, VCM = 2V 25°C 4 +IB, VCM = –2V –40°C –8 –15 –IB, VCM = –2V 2 125°C –10 –20 0 1.8 2.3 2.8 3.3 3.8 4.3 4.8 5.3 –40 –25 –10 5 20 35 50 65 80 95 110 125 0 0.5 1 1.5 2 2.5 3 3.5 4 4.5 5 SUPPLY VOLTAGE (V) TEMPERATURE (°C) SUPPLY VOLTAGE (V) 6258 G10 6262 G11 6258 G12
Supply Current Output Saturation Voltage Output Saturation Voltage vs Temperature Per Channel vs Load Current vs Load Current
25 0 350 VS = 5V VCM = 0.4V –40°C/5V VS = 1.8V –50 25°C/5V 300 20 85°C/5V 125°C/5V –100 TOM RAIL (mV) 250 –40°C/1.8V 25°C/1.8V 15 –150 200 85°C/1.8V 125°C/1.8V –40°C/5V Y CURRENT (µA) 10 –200 TAGE FROM TOP RAIL (mV) 25°C/5V 150 85°C/5V TAGE FROM BOT SUPPL –250 125°C/5V 100 5 –40°C/1.8V TION VOL 25°C/1.8V –300 TION VOL 50 85°C/1.8V TURA SA 125°C/1.8V TURA 0 –350 0 SA –50 –20 10 40 70 100 130 0 0.5 1 1.5 2 0 0.5 1 1.5 2 TEMPERATURE (°C) LOAD CURRENT (mA) LOAD CURRENT (mA) 6258 G13 6258 G14 6258 G15
Output Short-Circuit Current Output Short-Circuit Current 0.1Hz to 10Hz Output vs Supply Voltage (Sourcing) vs Supply Voltage (Sinking) Voltage Noise
25 30 5 V V V CM = 0.4V CM = 0.4V S = ±2.5V 4 VCM = 0.4V 25 20 AV = 1 3 V) 2 20 15 1 15 TAGE (µ 0 10 –1 10 125°C NOISE VOL –2 25°C 5 –40°C –3 5 125°C MAXIMUM SOURCING CURRENT (mA) MAXIMUM SINKING CURRENT (mA) 25°C –4 –40°C 0 0 –5 1.8 2.3 2.8 3.3 3.8 4.3 4.8 5.3 1.8 2.3 2.8 3.3 3.8 4.3 4.8 5.3 0 1 2 3 4 5 6 7 8 9 10 SUPPLY VOLTAGE (V) SUPPLY VOLTAGE (V) TIME (s) 6258 G16 6259 G17 6258 G18 6258960fa 8 For more information www.linear.com/LTC6258 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information 5V Electrical Characteristics 1.8V Electrical Characteristics Typical Performance Characteristics Pin Functions Simplified Schematic Operation Applications Information Typical Application Related Parts
