Datasheet LTC6261, LTC6262, LTC6263 (Analog Devices)
Description30MHz, 240µA Power Efficient Rail-to-Rail I/O Op Amps
Pages / Page26 / 1 — FeAtures. Description. Gain Bandwidth Product: 30MHz. Low Quiescent …
FeAtures. Description. Gain Bandwidth Product: 30MHz. Low Quiescent Current: 240µA. Op Amp Drives up to 1nF Capacitive Loads
Datasheet LTC6261, LTC6262, LTC6263 Analog Devices
LTC6261/LTC6262/LTC6263 30MHz, 240µA Power Efficient Rail-to-Rail I/O Op Amps
FeAtures Description
n
The LTC®6261/LTC6262/LTC6263 are single/dual/quad op- n
erational amplifiers with low noise, low power, low supply n
voltage, and rail-to-rail inputs and outputs. They are unity n
Offset Voltage: 400µV Maximum
gain stable with capacitive loads up to 1nF. They feature n
Rail-to-Rail Input and Output
30MHz gain-bandwidth product, 7V/µs slew rate while n
Supply Voltage Range: 1.8V to 5.25V
consuming only 240µA of supply current per amplifier n Input Bias Current: 100nA Maximum operating on supply voltages ranging from 1.8V to 5.25V. n CMRR/PSRR: 100dB/95dB The combination of low supply current, low supply voltage, n Shutdown Current: 10µA Maximum high gain bandwidth product and low noise makes the n Operating Temperature Range: –40°C to 125°C LTC6261 family unique among rail-to-rail input/output op n Single in 6-Lead TSOT-23, 2mm × 2mm DFN amps with similar supply current. These operational ampli- Packages fiers are ideal for low power and low noise applications. n Dual in 8-Lead MS8, MS10, TS0T-23, 2mm × 2mm For applications that require power-down, the LTC6261 DFN Packages and LTC6262 in MSOP-10 offer shutdown which reduces n Quad in MS16 Package the current consumption to 10µA maximum.
ApplicAtions
The LTC6261 family can be used as plug-in replacements for many commercially available op amps to reduce power and improve input/output range and performance. n Micropower Active Filters n Portable Instrumentation L, LT, LTC, LTM, Linear Technology and the Linear logo are registered trademarks and Over-The-Top and C-Load are trademarks of Analog Devices, Inc. All other trademarks are the n Battery or Solar Powered Systems property of their respective owners. n Automotive Electronics
typicAl ApplicAtion Low Power, Low Distortion ADC Driver LTC6261 Driving LTC2362 ADC
0 CF1 VIN = –1dBFS, 5kHz 10pF –10 fS = 250kSps –20 SNR = 72dB THD = –83.6dB –30 SFDR = 86dB RF1 –40 1.74k 3.3V –50 –60 RF2 3.3V –70 2.74k – VDD VREF MAGNITUDE (dB) –80 U1 RFILT CS 100Ω –90 OUT SDO LTC6261 AIN LTC2362 –100 + SCK IN CFILT –110 10nF OV GND DD –120 0 10 20 30 40 50 60 FREQUENCY (kHz) 626123 TA01a 626123 TA01b 626123fa For more information www.linear.com/LTC6261 1 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information 5V Electrical Characteristics 1.8V Electrical Characteristics Typical Performance Characteristics Pin Functions Simplified Schematic Operation Applications Information Package Description Typical Application Related Parts
