Datasheet RH108A (Analog Devices) - 4
Description | Operational Amplifier |
Pages / Page | 4 / 4 — TYPICAL PERFORMANCE CHARACTERISTICS. Input Offset Voltage. Input Bias … |
File Format / Size | PDF / 71 Kb |
TYPICAL PERFORMANCE CHARACTERISTICS. Input Offset Voltage. Input Bias Current. Input Offset Current. Open-Loop Gain
RH108A
TYPICAL PERFORMANCE CHARACTERISTICS Input Offset Voltage Input Bias Current Input Offset Current
1.5 6 1.5 VS = 15V VS = 15V VS = 15V V V V 1.0 CM = 0V 4 CM = 0V 1.0 CM = 0V 0.5 2 0.5 0 0 0 –0.5 –2 –0.5 –1.0 –4 –1.0 INPUT BIAS CURRENT (nA) INPUT OFFSET VOLTAGE (mV) INPUT OFFSET CURRENT (nA) –1.5 –6 –1.5 –2.0 –8 –2.0 1 10 100 1000 1 10 100 1000 1 10 100 1000 TOTAL DOSE KRAD (Si) TOTAL DOSE KRAD (Si) TOTAL DOSE KRAD (Si) RH108A G01 RH108A G02 RH108A G03
Open-Loop Gain Common Mode Rejection Ratio Power Supply Rejection Ratio
140 160 160 VS = 15V VS = 15V VOUT = 10V V 130 150 CM = 13.5V R 140 L = 10k 140 120 120 130 110 120 100 100 110 80 100 90 60 OPEN-LOOP GAIN (V/mV) 90 80 40 80 COMMON MODE REJECTION RATIO (dB) POWER SUPPLY REJECTION RATIO (dB) 70 70 20 1 10 100 1000 1 10 100 1000 1 10 100 1000 TOTAL DOSE KRAD (Si) TOTAL DOSE KRAD (Si) TOTAL DOSE KRAD (Si) RH108A G04 RH108A G05 RH108A G06 rh108afc 4 Linear Technology Corporation ID No. 66-10-0156 • LT 1110 REV C • PRINTED IN USA 1630 McCarthy Blvd., Milpitas, CA 95035-7417 (408) 432-1900 ● FAX: (408) 434-0507 ● www.linear.com © LINEAR TECHNOLOGY CORPORATION 1989
