Datasheet LTC3636, LTC3636-1 (Analog Devices)
DescriptionDual Channel 6A, 20V Monolithic Synchronous Step-Down Regulator
Pages / Page28 / 1 — FEATURES. DESCRIPTION. Wide VIN Range: 3.1V to 20V. Wide VOUT Range:. …
File Format / SizePDF / 944 Kb
FEATURES. DESCRIPTION. Wide VIN Range: 3.1V to 20V. Wide VOUT Range:. 0.6V to 5V (LTC3636). 1.8V to 12V (LTC3636-1)
Datasheet LTC3636, LTC3636-1 Analog Devices
LTC3636/LTC3636-1 Dual Channel 6A, 20V Monolithic Synchronous Step-Down Regulator
FEATURES DESCRIPTION
n
The LTC®3636/LTC3636-1 is a high efficiency, dual-channel n
Wide VOUT Range:
monolithic synchronous buck regulator using a controlled
on-time current mode architecture, with phase lockable
switching frequency. The operating supply voltage range is n
Output Current per Channel: 6A
from 3.1V to 20V, making it suitable for lithium-ion battery n
High Efficiency: Up to 95%
stacks as well as point of load power supply applications n
Die Temperature Monitor
from a 12V or 5V input. n
Adjustable Switching Frequency: 500kHz to 4MHz
The operating frequency is programmable from 500kHz to n
External Frequency Synchronization
4MHz with an external resistor and may be synchronized n
Current Mode Operation for Excellent Line and
to an external clock signal. The high frequency capability
Load Transient Response
allows the use of small surface mount inductors and n 0.6V Reference Allows Low Output Voltages capacitors. The unique constant frequency/controlled n User Selectable Burst Mode® Operation or Forced on-time architecture is ideal for high step-down ratio ap- Continuous Operation plications that operate at high frequency while demanding n Output Voltage Tracking and Soft-Start Capability fast transient response. n Short-Circuit Protected n Overvoltage Input and Overtemperature Protection The LTC3636/LTC3636-1 can select between forced con- n Power Good Status Outputs tinuous mode and high efficiency Burst Mode operation. n Low Profile 4mm × 5mm 28-Lead QFN Package The LTC3636 and LTC3636-1 differ in their output voltage sense range.
All registered trademarks and trademarks are the property of their respective owners. Protected by U.S. Patents including 5481178, 5847554, 6580258, 6304066, 6476589, 6774611. n Distributed Power Systems n Battery-Powered Instruments n Point-of-Load Power Supplies
TYPICAL APPLICATION
VIN 10V TO 20V
Efficiency vs Load Current
47µF VIN2 VIN1 x2 100 RUN1 INTVCC fSW = 2MHz RUN2 ITH1 4.7µF 97 LTC3636/ VIN = 12V LTC3636-1 ITH2 94 RT 91 TMON MODE/SYNC TRACKSS2 TRACKSS1 88 PGOOD2 PGOOD1 85 BOOST2 BOOST1 82 0.1µF 0.1µF EFFICIENCY (%) 0.56µH 0.56µH 79 VOUT2 SW2 SW1 VOUT1 5V AT 6A 3.3V AT 6A 76 47µF 47µF 73.2k 45.3k V 73 OUT = 5V 22pF 22pF VOUT = 3.3V VFB2 GND VFB1 70 10k 10k 0 0.6 1.2 1.8 2.4 3 3.6 4.2 4.8 5.4 6.0 LOAD CURRENT (A) 3636 TA01a 3636 TA01b 3636fb For more information www.linear.com/LTC3636 1 Document Outline Description Typical Application Absolute Maximum Ratings Pin Configuration Electrical Characteristics Typical Performance Characteristics Pin Functions Operation Applications Information Package Description Typical Application Related Parts
