ADP5304Data SheetPIN CONFIGURATION AND FUNCTION DESCRIPTIONSEN 110 PVINNC 29 SWADP5304MODE 38 PGNDTOP VIEW(Not to Scale)VID 47 AGNDFB 56 VINOKNOTES1. NC = NO CONNECT.2. EXPOSED PAD. SOLDER THE EXPOSED PAD TO A LARGE 03 0 EXTERNAL COPPER GROUND PLANE UNDERNEATH THE 3- IC FOR THERMAL DISSIPATION. 49 13 Figure 3. Pin Configuration Table 4. Pin Function Descriptions Pin No.MnemonicDescription 1 EN Enable Input for the Regulator. A logic low on this pin disables the regulator. 2 NC No Connect. Connect this pin to ground. 3 MODE Operating Mode Pin. Connect this pin to ground; the regulator operates in hysteresis mode. 4 VID Voltage Configuration Pin. Connect one resistor from this pin to ground to configure the output voltage of the regulator. 5 FB Feedback Sensing Input for the Regulator. 6 VINOK Input Power-Good Signal. This open-drain output is the power-good signal for the input voltage. 7 AGND Analog Ground. 8 PGND Power Ground. 9 SW Switching Node Output for the Regulator. 10 PVIN Power Input for the Regulator. EPAD Exposed Pad. Solder the exposed pad to a large external copper ground plane underneath the IC for thermal dissipation. Rev. 0 | Page 6 of 17 Document Outline FEATURES APPLICATIONS TYPICAL APPLICATION CIRCUIT GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY DETAILED FUNCTIONAL BLOCK DIAGRAM SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION BUCK REGULATOR OPERATIONAL MODE ADJUSTABLE AND FIXED OUTPUT VOLTAGES UNDERVOLTAGE LOCKOUT (UVLO) ENABLE/DISABLE VINOK FUNCTION CURRENT LIMIT SHORT-CIRCUIT PROTECTION SOFT START STARTUP WITH PRECHARGED OUTPUT 100% DUTY OPERATION ACTIVE DISCHARGE THERMAL SHUTDOWN APPLICATIONS INFORMATION EXTERNAL COMPONENT SELECTION SELECTING THE INDUCTOR OUTPUT CAPACITOR INPUT CAPACITOR LAYOUT RECOMMENDATIONS TYPICAL APPLICATION CIRCUITS FACTORY PROGRAMMABLE OPTIONS OUTLINE DIMENSIONS ORDERING GUIDE
