Datasheet ADP5304 (Analog Devices) - 8 Manufacturer Analog Devices Description Ultralow Power Step-Down Regulator with Input Voltage Monitor and Regulation Pages / Page 17 / 8 — ADP5304. Data Sheet. 160. 350. 140. –40ºC. +25ºC. +85ºC. 300. A) 120. … File Format / Size PDF / 562 Kb Document Language English
ADP5304. Data Sheet. 160. 350. 140. –40ºC. +25ºC. +85ºC. 300. A) 120. +125ºC. T N 100. NT 250. RRE. N CURRE. 200. CE S E. HUT. Q 150. 100. 2.3. 2.9. 3.5. 4.1. 4.7. 5.3
Model Line for this Datasheet Text Version of Document ADP5304 Data Sheet 160 350 140 –40ºC –40ºC +25ºC +25ºC +85ºC 300 +85ºC A) 120 A) n +125ºC n +125ºC ( ( T N 100 NT 250 RRE 80 CU N CURRE T W N 60 200 DO CE S E HUT UI S 40 Q 150 20 0 100 52.3 2.9 3.5 4.1 4.7 5.3 5.9 6.5 -0122.3 2.9 3.5 4.1 4.7 5.3 5.9 6.5 01V 493-IN (V) 493VIN (V) 13 13 Figure 10. Shutdown Current vs. VIN, EN = Low Figure 13. Quiescent Current vs. VIN700 400 –40ºC –40ºC 600 +25ºC 350 +25ºC ) +125ºC +125ºC ) Ω Ω (m 500 (m 300 ) H L N N) O O ( DS ( 400 DS 250 R R E E ID ID S -S H- 300 200 G HI LOW 200 150 100 100 2.3 2.9 3.5 4.1 4.7 5.3 5.9 6.5 -0172.3 2.9 3.5 4.1 4.7 5.3 5.9 6.5 -020VIN (V) 493VIN (V) 493 13 13 Figure 11. High-Side RDS (ON) H vs. VIN Figure 14. Low-Side RDS (ON) L vs. VIN810 808 VOUT ACTIVE TO STANDBY ) 806 V 1 m ( SW E 804 AG STANDBY TO ACTIVE T L 802 O 800 ACK V 2 DB 798 I E L E F 796 4 794 792 -023–40 25 85 125 -019CH1 100mV CH2 2.00V M 200µs C A H4 140mA 93TEMPERATURE (°C) CH4 500mA Ω T 39.60% 3493 1 134 Figure 12. Feedback Voltage vs. Temperature Figure 15. Steady Waveform, ILOAD = 1 mA (IL is the Inductor Current) Rev. 0 | Page 8 of 17 Document Outline FEATURES APPLICATIONS TYPICAL APPLICATION CIRCUIT GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY DETAILED FUNCTIONAL BLOCK DIAGRAM SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION BUCK REGULATOR OPERATIONAL MODE ADJUSTABLE AND FIXED OUTPUT VOLTAGES UNDERVOLTAGE LOCKOUT (UVLO) ENABLE/DISABLE VINOK FUNCTION CURRENT LIMIT SHORT-CIRCUIT PROTECTION SOFT START STARTUP WITH PRECHARGED OUTPUT 100% DUTY OPERATION ACTIVE DISCHARGE THERMAL SHUTDOWN APPLICATIONS INFORMATION EXTERNAL COMPONENT SELECTION SELECTING THE INDUCTOR OUTPUT CAPACITOR INPUT CAPACITOR LAYOUT RECOMMENDATIONS TYPICAL APPLICATION CIRCUITS FACTORY PROGRAMMABLE OPTIONS OUTLINE DIMENSIONS ORDERING GUIDE
