Datasheet ADP5310 (Analog Devices) - 4
Description3-Channel, Integrated Ultralow Power Solution with Dual Buck Regulators and Load Switch
Pages / Page28 / 4 — ADP5310. Data Sheet. SPECIFICATIONS. Table 1. Parameter. Symbol. Min. …
RevisionA
File Format / SizePDF / 796 Kb
ADP5310. Data Sheet. SPECIFICATIONS. Table 1. Parameter. Symbol. Min. Typ. Max. Unit. Test Conditions/Comments
ADP5310 Data Sheet SPECIFICATIONS Table 1 Parameter Symbol Min Typ Max Unit Test Conditions/Comments
VIN = 6 V, VREG = 3.9 V, TJ = −40°C to +125°C for minimum and maximum specifications, and TA = 25°C for typical specifications, unless otherwise noted.
Table 1. Parameter Symbol Min Typ Max Unit Test Conditions/Comments
INPUT SUPPLY VOLTAGE RANGE VIN 2.7 15.0 V PVIN1 and PVIN2 pins QUIESCENT CURRENT PVIN1 and PVIN2 pins Operating Quiescent Current Standby Operation IQ1 700 1850 nA −40°C ≤ TJ ≤ +85°C, EN1 = SYNC/MODE = low 700 3800 nA −40°C ≤ TJ ≤ +125°C, EN1 = SYNC/MODE = low PWM Operation IQ3 1.4 1.65 mA EN1 = SYNC/MODE = high UNDERVOLTAGE LOCKOUT UVLO PVIN2 pin UVLO Threshold Rising VUVLO_RISING 2.55 2.75 V Fal ing VUVLO_FALLING 2.15 2.40 V Hysteresis VHYS 150 mV OSCILLATOR CIRCUIT For Channel 1 and Channel 2, PWM mode Switching Frequency fSW 1050 1200 1350 kHz 525 600 675 kHz Feedback (FB) Threshold of VOSC_FOLD 0.3 V Frequency Fold SYNCHRONIZATION THRESHOLD SYNC Clock Range SYNCCLOCK 400 800 kHz fSW = 600 kHz SYNCCLOCK 800 1400 kHz fSW = 1.2 MHz SYNC High Level Threshold SYNCHIGH 1.2 V SYNC Low Level Threshold SYNCLOW 0.4 V SYNC Pulse On Time Range SYNCON 80 1/fSW − 150 ns EN1 and EN3 Input High Level Threshold VIH 1.2 V Input Low Level Threshold VIL 0.4 V Input Leakage Current ILEAKAGE 300 nA INTERNAL POWER GOOD Internal Power-Good Threshold VPWRGD(RISE) 88 92 96 % Internal Power-Good Hysteresis VPWRGD(HYS) 5 % Internal Power-Good Rising Delay tPWRGD_RISE 16 Clock cycles Internal Power-Good Falling Delay tPWRGD_FALL 1 µs Leakage Current for PWRGD Pin IPWRGD_LEAKAGE 10 40 nA Output Low Voltage for PWRGD Pin VPWRGD_LOW 50 100 mV IPWRGD = 100 µA INTERNAL REGULATOR VREG Output Voltage VREG 3.6 3.9 4.2 V THERMAL SHUTDOWN Threshold TSHDN 135 °C Hysteresis THYS 15 °C Rev. A | Page 4 of 28 Document Outline FEATURES APPLICATIONS TYPICAL APPLICATION CIRCUIT GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY DETAILED FUNCTIONAL BLOCK DIAGRAM SPECIFICATIONS BUCK REGULATORS AND LOAD SWITCH SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION BUCK REGULATOR OPERATION MODES PWM Mode PSM Mode Hysteresis Mode Mode Selection ADJUSTABLE AND FIXED OUTPUT VOLTAGES UNDERVOLTAGE LOCKOUT (UVLO) ENABLE AND SHUTDOWN FEATURES INTERNAL LINEAR REGULATOR (VREG) OSCILLATOR AND SYNCHRONIZATION CURRENT LIMIT SHORT-CIRCUIT PROTECTION SOFT START STARTUP WITH PRECHARGED OUTPUT 100% DUTY OPERATION ACTIVE DISCHARGE POWER-GOOD FUNCTION LOAD SWITCH THERMAL SHUTDOWN APPLICATIONS INFORMATION EXTERNAL COMPONENT SELECTION SELECTING THE INDUCTOR OUTPUT CAPACITOR INPUT CAPACITOR ADJUSTABLE OUTPUT VOLTAGE PROGRAMMING EFFICIENCY Power Switch Conduction Losses Inductor Losses Driver Losses Transition Losses RECOMMENDED BUCK EXTERNAL COMPONENTS CAPACITOR SELECTION Output Capacitor Input Bypass Capacitor Input and Output Capacitor Properties CIRCUIT BOARD LAYOUT RECOMMENDATIONS TYPICAL APPLICATION CIRCUITS FACTORY PROGRAMMABLE OPTIONS OUTLINE DIMENSIONS ORDERING GUIDE
