Datasheet ADP2311 (Analog Devices) - 7
DescriptionDual 1 A, 18 V, Synchronous Step-Down Regulator with Fail-Safe Voltage Monitoring
Pages / Page20 / 7 — Data Sheet. ADP2311. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. 1 N. B1 …
File Format / SizePDF / 698 Kb
Data Sheet. ADP2311. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. 1 N. B1 F. VM2. PVI. GND 1. 18 PGND1. VREG 2. 17 PGND1. TIMER 3. BST1. PFI 4
Data Sheet ADP2311 PIN CONFIGURATION AND FUNCTION DESCRIPTIONS 1 N B1 F VM2 PVI GND 1 18 PGND1 VREG 2 17 PGND1 TIMER 3 BST1 PFI 4
link to page 14
Data Sheet ADP2311 PIN CONFIGURATION AND FUNCTION DESCRIPTIONS 1 N 1 1 B1 F VM2 EN PVI SW SW 24 23 22 21 20 19 GND 1 18 PGND1 VREG 2 17 PGND1 TIMER 3 16 ADP2311 BST1 PFI 4 TOP VIEW 15 BST2 PFO 5 14 PGND2 POR 6 13 PGND2 7 8 9 1 10 1 12 O 2 2 2 DI B2 T N F W SW SW RS PVI NOTES
004
1. SOLDER THE EXPOSED PAD TO AN EXTERNAL GND PLANE.
1036- 1 Figure 4. Pin Configuration
Table 4. Pin Function Descriptions Pin No. Mnemonic Description
1 GND Analog Ground. Connect this pin to the ground plane. 2 VREG Internal 5 V Regulator Output. The IC control circuits are powered from this voltage. Place a 1 µF ceramic capacitor between VREG and GND. 3 TIMER POR Sequence Selection and Delay Time Setting. This pin is used to set the POR sequence and delay time (see the TIMER Pin Configuration section). 4 PFI Power Fail Comparator Input. Connect an external resistor divider from PVIN2 to PFI to monitor the input voltage. When the PFI voltage falls below the threshold voltage, the PFO pin is pulled low. 5 PFO Power Fail Output (Open Drain). 6 POR Power-On Reset Output (Open Drain). 7 FB2 Feedback Voltage Sense Input for Channel 2. Connect this pin to a resistor divider from the Channel 2 output voltage, VOUT2. 8 RSTO Watchdog Output (Open Drain). The RSTO pin goes low if the internal watchdog timer times out because of inactivity on the WDI input. 9 WDI Watchdog Input. If WDI remains high or low for longer than the watchdog timeout period, the watchdog output, RSTO, goes low. The timer is reset with each transition at the WDI input; a high to low or low to high transition clears the counter. 10 PVIN2 Power Input for Channel 2. Connect PVIN2 to the input power source, and connect a bypass capacitor between this pin and PGND2. 11, 12 SW2 Switch Node for Channel 2. 13, 14 PGND2 Power Ground for Channel 2. 15 BST2 Supply Rail for the Gate Drive of Channel 2. Place a 0.1 µF capacitor between SW2 and BST2. 16 BST1 Supply Rail for the Gate Drive of Channel 1. Place a 0.1 µF capacitor between SW1 and BST1. 17, 18 PGND1 Power Ground for Channel 1. 19, 20 SW1 Switch Node for Channel 1. 21 PVIN1 Power Input for Channel 1. Connect PVIN1 to the input power source, and connect a bypass capacitor between this pin and PGND1. 22 EN Precision Enable Input. An external resistor divider can be used to set the turn-on threshold. If the enable pin is not used, connect EN to PVINx. 23 VM2 Voltage Monitor Comparator Input. Connect an external resistor divider from PVIN2 to VM2 to monitor the input voltage. During the power-down sequence, Channel 2 turns off when the VM2 voltage falls below the threshold voltage. 24 FB1 Feedback Voltage Sense Input for Channel 1. Connect this pin to a resistor divider from the Channel 1 output voltage, VOUT1. EP Exposed Pad. Solder the exposed pad to an external GND plane. Rev. B | Page 7 of 20 Document Outline Features Applications Typical Application Circuit General Description Revision History Functional Block Diagram Specifications Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Control Scheme Precision Enable/Shutdown Internal Regulator (VREG) Bootstrap Circuitry Soft Start Peak Current-Limit and Short-Circuit Protection Power-On Reset (POR) TIMER Pin Configuration Power Fail Comparator Voltage Monitor Comparator (VM2) Watchdog Timer Power-Up and Power-Down Sequence Overvoltage Protection (OVP) Undervoltage Lockout (UVLO) Thermal Shutdown Applications Information Input Capacitor Selection Output Voltage Setting Inductor Selection Output Capacitor Selection Application Circuit Outline Dimensions Ordering Guide
