Datasheet LTC3633A, LTC3633A-1 (Analog Devices) - 2
Description | Dual Channel 3A, 20V Monolithic Synchronous Step-Down Regulator |
Pages / Page | 30 / 2 — ABSOLUTE MAXIMUM RATINGS (Note 1). PIN CONFIGURATION. ORDER INFORMATION … |
File Format / Size | PDF / 417 Kb |
ABSOLUTE MAXIMUM RATINGS (Note 1). PIN CONFIGURATION. ORDER INFORMATION LEAD FREE FINISH. TAPE AND REEL. PART MARKING*
LTC3633A/LTC3633A-1
VIN1, VIN2 ... –0.3V to 20V VFB1, VFB2, PHMODE. ..–0.3V to INTVCC + 0.3V PGOOD1, PGOOD2, VON1, VON2 ... –0.3V to 18V RUN1, RUN2 .. –0.3V to VIN + 0.3V BOOST1, BOOST2 .. –0.3V to 23V Operating Junction Temperature Range BOOST1-SW1, BOOST2-SW2 ... –0.3V to 3.6V (Notes 2, 3) .. –40°C to 125°C V2P5, INTVCC, TRACKSS1, TRACKSS2 .. –0.3V to 3.6V Storage Temperature Range ... –65°C to 150°C ITH1, ITH2, RT, MODE/SYNC ..–0.3V to INTVCC + 0.3V
PIN CONFIGURATION
TOP VIEW TOP VIEW ITH1 1 28 VON1 TRACKSS1 2 27 SW1 V FB1 TRACKSS1 ITH1 V ON1 SW1 SW1 28 27 26 25 24 23 V 3 26 FB1 SW1 PGOOD1 1 22 V PGOOD1 4 V IN1 25 IN1 PHMODE 2 21 VIN1 PHMODE 5 24 VIN1 RUN1 3 20 BOOST1 RUN1 6 23 BOOST1 MODE/SYNC 4 19 INTV 29 CC MODE/SYNC 7 29 22 INTVCC RT 5 PGND 18 V2P5 PGND RT 8 21 V2P5 RUN2 6 17 BOOST2 RUN2 9 20 BOOST2 SGND 7 16 VIN2 SGND 10 19 VIN2 PGOOD2 8 15 VIN2 PGOOD2 11 18 VIN2 9 10 11 12 13 14 V 12 17 FB2 SW2 V FB2 ITH2 V ON2 SW2 SW2 TRACKSS2 13 16 SW2 ITH2 14 15 V TRACKSS2 ON2 UFD PACKAGE FE PACKAGE 28-LEAD (4mm × 5mm) PLASTIC QFN 28-LEAD PLASTIC TSSOP TJMAX = 125°C, θJA = 43°C/W TJMAX = 125°C, θJA = 30°C/W EXPOSED PAD (PIN 29) IS PGND, MUST BE SOLDERED TO PCB EXPOSED PAD (PIN 29) IS PGND, MUST BE SOLDERED TO PCB
LTC3633AEUFD#PBF LTC3633AEUFD#TRPBF 3633A 28-Lead (4mm × 5mm) Plastic QFN –40°C to 125°C LTC3633AIUFD#PBF LTC3633AIUFD#TRPBF 3633A 28-Lead (4mm × 5mm) Plastic QFN –40°C to 125°C LTC3633AEFE#PBF LTC3633AEFE#TRPBF LTC3633AFE 28-Lead Plastic TSSOP –40°C to 125°C LTC3633AIFE#PBF LTC3633AIFE#TRPBF LTC3633AFE 28-Lead Plastic TSSOP –40°C to 125°C LTC3633AEUFD-1#PBF LTC3633AEUFD-1#TRPBF 633A1 28-Lead (4mm × 5mm) Plastic QFN –40°C to 125°C LTC3633AIUFD-1#PBF LTC3633AIUFD-1#TRPBF 633A1 28-Lead (4mm × 5mm) Plastic QFN –40°C to 125°C LTC3633AEFE-1#PBF LTC3633AEFE-1#TRPBF LTC3633AFE-1 28-Lead Plastic TSSOP –40°C to 125°C LTC3633AIFE-1#PBF LTC3633AIFE-1#TRPBF LTC3633AFE-1 28-Lead Plastic TSSOP –40°C to 125°C Consult LTC Marketing for parts specified with wider operating temperature ranges. *The temperature grade is identified by a label on the shipping container. Consult LTC Marketing for information on non-standard lead based finish parts. For more information on lead free part marking, go to: http:/ www.linear.com/leadfree/ For more information on tape and reel specifications, go to: http://www.linear.com/tapeandreel/ 3633a1fb 2 For more information www.linear.com/LTC3633A Document Outline Description Typical Application Absolute Maximum Ratings Pin Configuration Electrical Characteristics Typical Performance Characteristics Pin Functions Operation Applications Information Package Description Typical Application Related Parts
