Datasheet LTC3388-1, LTC3388-3 (Analog Devices) - 2
Description20V High Efficiency Nanopower Step-Down Regulator
Pages / Page22 / 2 — ABSOLUTE MAXIMUM RATINGS (Note 1). PIN CONFIGURATION. ORDER INFORMATION …
File Format / SizePDF / 381 Kb
ABSOLUTE MAXIMUM RATINGS (Note 1). PIN CONFIGURATION. ORDER INFORMATION LEAD FREE FINISH. TAPE AND REEL. PART MARKING*
ABSOLUTE MAXIMUM RATINGS (Note 1) PIN CONFIGURATION ORDER INFORMATION LEAD FREE FINISH TAPE AND REEL PART MARKING*
LTC3388-1/LTC3388-3
VIN ... –0.3V to 22V ISW ...210mA D0, D1 ..–0.3V to [Lesser of (VIN2 + 0.3V) or 6V] Operating Junction Temperature Range CAP ..[Higher of –0.3V or (VIN – 6V)] to VIN (Notes 2, 3) .. –40°C to 125°C VIN2, VOUT ..–0.3V to [Lesser of (VIN + 0.3V) or 6V] Storage Temperature Range .. –65°C to 125°C EN, STBY ... –0.3V to 6V Lead Temperature (Soldering, 10 sec) PGOOD ... –0.3V to 6V MSE Only ..300°C
PIN CONFIGURATION
TOP VIEW TOP VIEW EN 1 10 PGOOD EN 1 10 PGOOD STBY 2 9 D0 11 STBY 2 9 D0 11 CAP 3 GND 8 D1 CAP 3 8 D1 GND V VIN 4 7 VIN2 IN 4 7 VIN2 SW 5 6 VOUT SW 5 6 VOUT MSE PACKAGE 10-LEAD PLASTIC MSOP DD PACKAGE 10-LEAD (3mm × 3mm) PLASTIC DFN T JMAX = 125°C, θJA = 45°C/W, θJC = 10°C/W EXPOSED PAD (PIN 11) IS GND, MUST BE SOLDERED TO PCB TJMAX = 125°C, θJA = 43°C/W, θJC = 7.5°C/W EXPOSED PAD (PIN 11) IS GND, MUST BE SOLDERED TO PCB
LTC3388EDD-1#PBF LTC3388EDD-1#TRPBF LFWN 10-Lead (3mm × 3mm) Plastic DFN –40°C to 125°C LTC3388IDD-1#PBF LTC3388IDD-1#TRPBF LFWN 10-Lead (3mm × 3mm) Plastic DFN –40°C to 125°C LTC3388EMSE-1#PBF LTC3388EMSE-1#TRPBF LTFWM 10-Lead Plastic MSOP –40°C to 125°C LTC3388IMSE-1#PBF LTC3388IMSE-1#TRPBF LTFWM 10-Lead Plastic MSOP –40°C to 125°C LTC3388EDD-3#PBF LTC3388EDD-3#TRPBF LFWQ 10-Lead (3mm × 3mm) Plastic DFN –40°C to 125°C LTC3388IDD-3#PBF LTC3388IDD-3#TRPBF LFWQ 10-Lead (3mm × 3mm) Plastic DFN –40°C to 125°C LTC3388EMSE-3#PBF LTC3388EMSE-3#TRPBF LTFWP 10-Lead Plastic MSOP –40°C to 125°C LTC3388IMSE-3#PBF LTC3388IMSE-3#TRPBF LTFWP 10-Lead Plastic MSOP –40°C to 125°C Consult LTC Marketing for parts specified with wider operating temperature ranges. *The temperature grade is identified by a label on the shipping container. Consult LTC Marketing for information on non-standard lead based finish parts. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifications, go to: http://www.linear.com/tapeandreel/ 338813fa 2 For more information www.linear.com/LTC3388 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Operation Applications Information Typical Application Related Parts
