Datasheet LT3570 (Analog Devices) - 2
Description1.5A Buck Converter, 1.5A Boost Converter and LDO Controller
Pages / Page20 / 2 — ABSOLUTE MAXIMUM RATINGS (Note 1). PIN CONFIGURATION. ORDER INFORMATION. …
File Format / SizePDF / 295 Kb
ABSOLUTE MAXIMUM RATINGS (Note 1). PIN CONFIGURATION. ORDER INFORMATION. LEAD FREE FINISH. TAPE AND REEL. PART MARKING*
ABSOLUTE MAXIMUM RATINGS (Note 1) PIN CONFIGURATION ORDER INFORMATION LEAD FREE FINISH TAPE AND REEL PART MARKING*
LT3570
VIN1, VIN2, VIN3, VBIAS Voltage ..40V VC1, VC2 Voltage ..3V BOOST Voltage ...60V Maximum Junction Temperature... 125°C BOOST Pin Above SW2 ...25V Operating Temperature Range (Note 2).. –40°C to 125°C NPN_DRV Voltage ...8V Storage Temperature Range SW1 Voltage ...40V TSSOP ... –65°C to 150°C SHDN1, SHDN2, SHDN3 Voltage ..40V QFN .. –65°C to 125°C SYNC, RT Voltage ..3V Lead Temperature (Soldering, 10 sec) SS1, SS2 Voltage ..3V TSSOP Only .. 300°C FB1, FB2, FB3 Voltage ...10V
PIN CONFIGURATION
TOP VIEW V TOP VIEW FB1 1 20 V IN3 C1 BOOST BIAS V NPN_DR FB3 FB2 SHDN1 2 19 SS1 24 23 22 21 20 19 SHDN2 3 18 VIN1 V 1 18 IN2 VC2 SHDN3 4 17 GND VIN2 2 17 SS2 SYNC 5 16 SW1 SW2 3 16 GND 21 25 SW1 4 15 R R 6 T 15 SW2 T GND 5 14 SYNC SS2 7 14 VIN2 GND 6 13 SHDN3 V 8 C2 13 BOOST FB2 9 12 V 7 8 9 10 11 12 IN3 FB3 10 11 NPN_DRV IN1 C1 V SS1 V FB1 SHDN1 SHDN2 FE PACKAGE UF PACKAGE 20-LEAD PLASTIC TSSOP 24-LEAD (4mm s 4mm) PLASTIC QFN TJMAX = 125°C, θJA = 38°C/W TJMAX = 125°C, θJA = 37°C/W EXPOSED PAD (PIN 21) IS GND, MUST BE SOLDERED TO PCB EXPOSED PAD (PIN 25) IS GND, MUST BE SOLDERED TO PCB
LT3570EUF#PBF LT3570EUF#TRPBF 3570 24-Lead (4mm × 4mm) Plastic QFN –40°C to 125°C LT3570IUF#PBF LT3570IUF#TRPBF 3570 24-Lead (4mm × 4mm) Plastic QFN –40°C to 125°C LT3570EFE#PBF LT3570EFE#TRPBF LT3570FE 20-Lead Plastic TSSOP –40°C to 125°C LT3570IFE#PBF LT3570IFE#TRPBF LT3570FE 20-Lead Plastic TSSOP –40°C to 125°C Consult LTC Marketing for parts specifi ed with wider operating temperature ranges. *The temperature grade is identifi ed by a label on the shipping container. Consult LTC Marketing for information on non-standard lead based fi nish parts. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifi cations, go to: http://www.linear.com/tapeandreel/ 3570fb 2
