Datasheet LTC3520 (Analog Devices) - 2
DescriptionSynchronous 1A Buck-Boost and 600mA Buck Converters
Pages / Page24 / 2 — ABSOLUTE MAXIMUM RATINGS. PIN CONFIGURATION. (Note 1). ORDER INFORMATION. …
File Format / SizePDF / 324 Kb
ABSOLUTE MAXIMUM RATINGS. PIN CONFIGURATION. (Note 1). ORDER INFORMATION. LEAD FREE FINISH. TAPE AND REEL. PART MARKING*
ABSOLUTE MAXIMUM RATINGS PIN CONFIGURATION (Note 1) ORDER INFORMATION LEAD FREE FINISH TAPE AND REEL PART MARKING*
LTC3520
TOP VIEW PVIN1, PVIN2, PVIN3, SVIN Voltage .. –0.3V to 6V SW1A, SW1B, SW2 Voltage IN3 IN1 OUT1 PV PV SW1A PGND1 SW1B V DC .. –0.3V to 6V 24 23 22 21 20 19 Pulsed <100ns .. –1V to 7V SV 1 18 IN FB1 Voltage, All Other Pins ... –0.3V to 6V AOUT 2 17 SS1 Operating Junction Temperature Range AIN 3 16 SGND 25 (Note 2) .. –40°C to 125°C R 4 15 T VC1 Maximum Junction Temperature (Note 5) .. 125°C PWM1 5 14 FB2 SD1 6 13 SS2 Storage Temperature Range .. –65°C to 150°C 7 8 9 10 11 12 SD2 SD3 IN2 PV SW2 WM2 PGND2 P UF PACKAGE 24-LEAD (4mm s 4mm) PLASTIC QFN TJMAX = 125°C, θJA = 37°C/W EXPOSED PAD (PIN 25) IS GND, MUST BE SOLDERED TO PCB
LTC3520EUF#PBF LTC3520EUF#TRPBF 3520 24-Lead (4mm × 4mm) Plastic QFN –40°C to 85°C LTC3520IUF#PBF LTC3520IUF#TRPBF 3520 24-Lead (4mm × 4mm) Plastic QFN –40°C to 125°C Consult LTC Marketing for parts specifi ed with wider operating temperature ranges. *The temperature grade is identifi ed by a label on the shipping container. Consult LTC Marketing for information on non-standard lead based fi nish parts. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifi cations, go to: http://www.linear.com/tapeandreel/
l
denotes the specifi cations which apply over the full operating junction temperature range, otherwise specifi cations are at TA = 25°C, SVIN = PVIN1 = PVIN2 = PVIN3 = 3.6V, VOUT1 = 3.3V, RT = 54.9k, unless otherwise noted. PARAMETER CONDITIONS MIN TYP MAX UNITS
Input Voltage l 2.2 5.5 V Quiescent Current in Shutdown VSD1 = VSD2 = VSD3 = 0V LTC3520E l 0.01 1 μA LTC3520I l 0.5 4 μA Undervoltage Lockout SVIN Rising 2 2.2 V Burst Mode Quiescent Current, Both Converters VFB1 = VFB2 = 0.88V, VSD3 = 0V 55 μA Oscillator Frequency RT = 54.9k l 0.8 1 1.2 MHz
Buck Converter
PMOS Switch Resistance 0.32 Ω NMOS Switch Resistance 0.18 Ω NMOS Switch Leakage VSW2 = 5V, SVIN = PVIN1 = PVIN2 = PVIN3 = 5V 0.1 5 μA PMOS Switch Leakage VSW2 = 0V, SVIN = PVIN1 = PVIN2 = PVIN3 = 5V 0.1 10 μA 3520fa 2
