Datasheet LTC3548-1 (Analog Devices) - 2
DescriptionDual Synchronous, Fixed Output 2.25MHz Step-Down DC/DC Regulator
Pages / Page16 / 2 — ABSOLUTE MAXIMUM RATINGS (Note 1). PIN CONFIGURATION. ORDER INFORMATION. …
File Format / SizePDF / 332 Kb
ABSOLUTE MAXIMUM RATINGS (Note 1). PIN CONFIGURATION. ORDER INFORMATION. LEAD FREE FINISH. TAPE AND REEL. PART MARKING
ABSOLUTE MAXIMUM RATINGS (Note 1) PIN CONFIGURATION ORDER INFORMATION LEAD FREE FINISH TAPE AND REEL PART MARKING
LTC3548-1
VIN Voltages ...– 0.3V to 6V Ambient Operating Temperature Range VFB1, VFB2, VOUT1, VOUT2 Voltages .. –0.3V to VIN + 0.3V (Note 2) ..– 40°C to 85°C RUN1, RUN2 Voltages ...–0.3V to VIN Junction Temperature (Note 5) ... 125°C SW1, SW2 Voltage ... –0.3V to VIN + 0.3V Storage Temperature Range ...– 65°C to 125°C
PIN CONFIGURATION
TOP VIEW TOP VIEW V 1 10 V FB1 FB2 V 1 10 V FB1 FB2 VOUT1 2 9 VOUT2 V 2 9 V V OUT1 OUT2 IN 3 11 8 RUN1 V 3 11 8 RUN1 SW1 IN 4 7 SW2 SW1 4 7 SW2 GND 5 6 RUN2 GND 5 6 RUN2 DD PACKAGE KD PACKAGE 10-LEAD (3mm × 3mm) PLASTIC DFN 10-LEAD (3mm × 3mm) PLASTIC UTDFN TJMAX = 125°C, θJA = 40°C/W, θJC = 3°C/W TJMAX = 125°C, θJA = 43°C/W, θJC = 10°C/W EXPOSED PAD (PIN 11) IS GND, MUST BE SOLDERED TO PCB GND EXPOSED PAD (PIN 11) IS GND, MUST BE SOLDERED TO PCB GND (SOLDERED TO A 4-LAYER BOARD) (SOLDERED TO A 4-LAYER BOARD)
ORDER INFORMATION LEAD FREE FINISH TAPE AND REEL PART MARKING PACKAGE DESCRIPTION TEMPERATURE RANGE
LTC3548EDD-1#PBF LTC3548EDD-1#TRPBF LBZC 10-Lead (3mm × 3mm) Plastic DFN –40°C to 85°C LTC3548EKD-1#PBF LTC3548EKD-1#TRPBF CXVT 10-Lead (3mm × 3mm) Plastic UTDFN –40°C to 85°C Consult LTC Marketing for parts specifi ed with wider operating temperature ranges. Consult LTC Marketing for information on non-standard lead based fi nish parts. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifi cations, go to: http://www.linear.com/tapeandreel/ 35481fc 2
