Datasheet LTC3448 (Analog Devices) - 2
Description1.5MHz/2.25MHz, 600mA Synchronous Step-Down Regulator with LDO Mode
Pages / Page20 / 2 — ABSOLUTE AXI U RATI GS (Note 1). PACKAGE/ORDER I FOR ATIO. ELECTRICAL …
File Format / SizePDF / 284 Kb
ABSOLUTE AXI U RATI GS (Note 1). PACKAGE/ORDER I FOR ATIO. ELECTRICAL CHARACTERISTICS The
ABSOLUTE AXI U RATI GS (Note 1) PACKAGE/ORDER I FOR ATIO ELECTRICAL CHARACTERISTICS The
LTC3448
W W W U ABSOLUTE AXI U RATI GS (Note 1)
Input Supply Voltage .. – 0.3V to 6V VOUT (LDO) Source Current .. 25mA RUN, SYNC Voltages ... – 0.3V to (VIN + 0.3V) Peak SW Sink and Source Current .. 1.3A MODE Voltage ... – 0.3V to (VIN + 0.3V) Operating Temperature Range (Note 2) .. – 40°C to 85°C FREQ, VFB Voltages.. – 0.3V to (VIN + 0.3V) Junction Temperature (Notes 3, 7) .. 125°C SW Voltage .. – 0.3V to (VIN + 0.3V) Storage Temperature Range .. – 65°C to 125°C VOUT Voltage .. – 0.3V to (VIN + 0.3V) Lead Temperature (Soldering, 10 sec) P-Channel Switch Source Current (DC) ... 800mA MSOP Only .. 300°C N-Channel Switch Sink Current (DC) ... 800mA
U W U PACKAGE/ORDER I FOR ATIO
TOP VIEW ORDER PART ORDER PART NUMBER NUMBER TOP VIEW V 1 8 FB RUN LTC3448EDD V 1 FB 8 RUN LTC3448EMS8E V 2 7 OUT SYNC V 2 7 SYNC 9 OUT 9 MODE 3 6 FREQ MODE 3 6 FREQ V 4 5 SW V IN IN 4 5 SW MS8E PACKAGE DD PART MARKING 8-LEAD PLASTIC MSOP MS8 PART MARKING DD PACKAGE TJMAX = 125°C, θJA = 40°C/ W 8-LEAD (3mm × 3mm) PLASTIC DFN LBMJ EXPOSED PAD (PIN 9) IS GND LTBMK TJMAX = 125°C, θJA = 43°C/ W MUST BE SOLDERED TO PCB EXPOSED PAD (PIN 9) IS GND MUST BE SOLDERED TO PCB Consult LTC Marketing for parts specified with wider operating temperature ranges.
denotes specifications which apply over the full operating temperature range, otherwise specifications are TA = 25
C. VIN = 3.6V unless otherwise specified. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
IVFB Feedback Current ● ±30 nA VFB Regulated Feedback Voltage TA = 25°C 0.5880 0.6 0.6120 V (Note 4) 0°C ≤ TA ≤ 85°C 0.5865 0.6 0.6135 V –40°C ≤ TA ≤ 85°C ● 0.5850 0.6 0.6150 V ∆VFB Reference Voltage Line Regulation VIN = 2.5V to 5.5V (Note 4) ● 0.2 0.4 %/V ∆VOVL Output Overvoltage Lockout ∆VOVL = VOVL – VFB 15 35 55 mV ∆VOVL = (VOVL – VOUT) • 100/VOUT 2.5 5.8 9.2 % ∆VOUT Output Voltage Line Regulation VIN = 2.5V to 5.5V (LDO) 0.1 0.8 %/V IPK Peak Inductor Current VFB = 0.5V or VOUT = 90%, 0.7 1 1.3 A Duty Cycle < 35% VLOADREG Output Voltage Load Regulation LDO, 1mA to 10mA 0.5 %/V VOUT(MAX) Maximum Output Voltage (Note 9) VIN – 0.7 VIN – 0.3 V VIN Input Voltage Range ● 2.5 5.5 V 3448f 2
