Datasheet LTC3811 (Analog Devices) - 3
DescriptionHigh Speed Dual, Multiphase Step-Down DC/DC Controller
Pages / Page48 / 3 — ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply …
File Format / SizePDF / 552 Kb
ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply over the full operating
ELECTRICAL CHARACTERISTICS The denotes the specifi cations which apply over the full operating
LTC3811
denotes the specifi cations which apply over the full operating junction temperature range, otherwise specifi cations are at TJ = 25°C. VIN = 12V, MODE/SYNC = 0V, unless otherwise specifi ed. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS Input Supply
VIN Operating Input Voltage Range 4.5 30 V IQ Total Quiescent Supply Current Continuous Mode (Note 4) VFB1,2 = 0.7V ● 10.5 20 mA Shutdown Mode VRUN1,2 = 0V ● 20 40 μA
RUN Pin ON/OFF Control
IRUN RUN Pin Input Leakage VRUN1,2 = 3.3V –1 1 μA VIL(RUN) Low Level RUN Input Threshold 0.3 V VIH(RUN) High Level RUN Input Threshold 1.8 V
Error Amplifi er Characteristics (Both Channels)
VFB1, VFB2 Feedback Voltage Accuracy (Note 5) 598 600 602 mV ● 597 603 mV IFB1, IFB2 Feedback Pin Input Current VCOMP = 1.25V (Note 5) –100 100 nA ΔVFB/ΔVIN Line Regulation 4.5V ≤ VIN ≤ 30V (Note 5) ● 0.002 0.02 %/V ΔVFB/ΔVCOMP Load Regulation ΔVCOMP = 1.25V to 1.5V (Note 5) ● –0.1 –0.01 % f0dB(EA) Error Amplifi er Unity Gain Crossover (Note 6) 8 MHz Frequency VOH(EA) Error Amplifi er Maximum Output VFB = 0.54V, No Load 2.6 V Voltage (Internally Clamped) VOL(EA) Error Amplifi er Minimum Output Voltage VFB = 0.66V, No Load 10 mV VFB(OFF) FB Voltage Threshold to Disable Error VINTVCC – VFB 0.3 V Amplifi er Output
Soft-Start/Tracking
ISS1, ISS2 SS/TRACK1, SS/TRACK2 Charging VSS/TRACK1 = VSS/TRACK2 = 0.3V –2.5 μA Currents RSS1, RSS2 SS/TRACK1, SS/TRACK2 Pull-Down VRUN1 = VRUN2 = 0V 1 kΩ Resistance in Shutdown
Differential Amplifi er
AV Differential Mode Gain, ΔVDIFF/IN = 1V to 3.5V, IDIFF/OUT = –100μA 0.995 1.000 1.005 V/V ΔVDIFF/OUT/ΔVDIFF/IN VOS(DIFF) Output Offset Voltage, VDIFF/IN+ = 1.25V, VDIFF/IN– = 0V, –6 6 mV VDIFF/OUT – VDIFF/IN+ IDIFF/OUT = –100μA RIN Input Resistance Measured at VDIFF/IN+ 160 kΩ PSRRDIFF Power Supply Rejection Ratio 7V ≤ VIN ≤ 30V 100 dB VDM(DIFF) Maximum Differential Mode Input VDIFF/IN+ – VDIFF/IN–, Measured at 5.5 V Voltage VDIFF/OUT, IDIFF/OUT = –100μA IMAX+ Maximum Sink Current 2 mA IMAX– Maximum Source Current –2 mA f0dB(DIFF) Unity Gain Bandwidth (Note 6) 8 MHz
Current Comparators
VSENSE(MAX) Maximum Current Sense Threshold VFB = 0.575V, VCM = 1.25V (VSENSE+ – VSENSE–) VRNG = 0V 14 24 34 mV VRNG = INTVCC 32.5 50 67.5 mV VRNG = 2V 60 85 110 mV VSENSE(MIN) Minimum Current Sense Threshold VFB = 0.625V, VCM = 1.25V (VSENSE+ – VSENSE–) VRNG = 0V –21 mV VRNG = INTVCC –41 mV VRNG = 2V –67 mV 3811f 3
