Datasheet LTC3811 (Analog Devices) - 4
Description | High Speed Dual, Multiphase Step-Down DC/DC Controller |
Pages / Page | 48 / 4 — ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply … |
File Format / Size | PDF / 552 Kb |
ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply over the full operating
LTC3811
denotes the specifi cations which apply over the full operating junction temperature range, otherwise specifi cations are at TJ = 25°C. VIN = 12V, MODE/SYNC = 0V, unless otherwise specifi ed. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
ISENSE Total Sense Pin Current VCM = 1.25V –1.5 μA (VSENSE+ + VSENSE–) VCM(CS) VSENSE+, VSENSE– Pin Common Mode 0 3.5 V Input Voltage Range
Voltage Position Amplifi er (QFN Package Only)
gm Voltage Position Transconductance, VSENSE1+ – VSENSE1– = VSENSE2+ 5.0 mS ΔICSOUT/ΔVSENSE (Note 8) – VSENSE2– = ±50mV, VCM = 1.25V, VCSOUT = 1.25V IOS(VP) Output Offset Current, Measured at VSENSE1+ – VSENSE1– = VSENSE2+ –40 40 μA CSOUT – VSENSE2– = 1.25V, VCSOUT = 1.25V
Multiphase Oscillator and Phase-Lock Loop (Note 9)
fNOM Nominal Frequency VPLL/LPF Pin Floating, MODE/SYNC = DC 450 500 550 kHz Voltage fLOW Lowest Frequency VPLL/LPF = 0V, MODE/SYNC = DC Voltage 200 250 300 kHz fHIGH Highest Frequency VPLL/LPF = INTVCC, MODE/SYNC = DC 650 750 850 kHz Voltage fSYNC(MIN) Minimum Synchronizable Frequency MODE/SYNC = External Clock 125 175 kHz fSYNC(MAX) Maximum Synchronizable Frequency MODE/SYNC = External Clock 900 1000 kHz IPLL/LPF Phase Detector Output Current Sinking fMODE/SYNC < fOSC –4.3 μA Sourcing fMODE/SYNC > fOSC 5.1 μA θ1 – θ2 Channel 1 to Channel 2 Phase VPHASMODE = 0V 180 deg Relationship (Note 9) VPHASMODE = 50% INTVCC 180 deg VPHASMODE = INTVCC 120 deg θ1 – θCLKOUT Channel 1 to CLKOUT Phase VPHASMODE = 0V 90 deg Relationship (Note 9) VPHASMODE = 50% INTVCC 60 deg VPHASMODE = INTVCC 240 deg VOL(CLKOUT) Low Level CLKOUT Output Voltage RCLK = 50k to Ground 0.2 V VOH(CLKOUT) High Level CLKOUT Output Voltage RCLK = 50k to Ground 4.0 5.8 V RMODE/SYNC MODE/SYNC Input Resistance 75 kΩ VIL(MODE/SYNC) Low Level MODE/SYNC Input Threshold 0.3 V VIH(MODE/SYNC) High Level MODE/SYNC Input Threshold 1.8 V
Power Good Indicators
VOL(PGOOD) PGOOD Voltage Low IPGOOD = 2mA 0.12 0.30 V IPGOOD(OFF) PGOOD Leakage Current VPGOOD = 6V 1.0 μA ΔVFB(OV) ΔVFB, PGOOD Overvoltage Threshold VFB(OV) – VFB(NOM) in Percent 7 10 13 % ΔVFB(UV) ΔVFB, PGOOD Undervoltage Threshold VFB(UV) – VFB(NOM) in Percent –13 –10 –7 % ΔVFB(HYST) ΔVFB, PGOOD Comparator Hysteresis UV or OV Comparator 12 mV tPG(FAULT) Delay from UV/OV Condition to PGOOD 145 μs Falling tPG(OK) Delay from UV/OV Fault Recovery to 38 μs PGOOD Rising
Thermal Protection
TJSD Thermal Shutdown Junction (Note 6) 165 °C Temperature TJSD(HYST) Thermal Shutdown Junction (Note 6) 25 °C Temperature Hysteresis 3811f 4
