Datasheet LTC3811 (Analog Devices) - 5
DescriptionHigh Speed Dual, Multiphase Step-Down DC/DC Controller
Pages / Page48 / 5 — ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply …
File Format / SizePDF / 552 Kb
ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply over the full operating
ELECTRICAL CHARACTERISTICS The denotes the specifi cations which apply over the full operating
LTC3811
denotes the specifi cations which apply over the full operating junction temperature range, otherwise specifi cations are at TJ = 25°C. VIN = 12V, MODE/SYNC = 0V, unless otherwise specifi ed. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS DRVCC Linear Regulator
VDRVCC LDO Regulator Output Voltage VEXTVCC = 0V ● 5.6 6.0 6.4 V ΔVDRVCC(LOAD) DRVCC Load Regulation ILOAD = 0mA to 50mA –2.0 –0.5 % ΔVDRVCC(LINE) DRVCC Line Regulation ΔVIN = 8.5V to 30V 0.01 0.2 %/V VDRVCC(UVLO) LDO Regulator Undervoltage Threshold DRVCC Rising 3.7 V VDRVCC(HYST) LDO Regulator Undervoltage Hysteresis 0.56 V VEXTVCC EXTVCC Switchover Voltage IDRVCC = 20mA, EXTVCC Rising 4.5 V VEXTVCC(HYST) EXTVCC Switchover Hysteresis IDRVCC = 20mA 400 mV VEXTVCC(DROP) EXTVCC Voltage Drop IDRVCC = 20mA, VEXTVCC = 5V 100 mV
Gate Drivers
tr (TG1, TG2) Top Gate Rise Time CL = 3300pF (Note 6) 20 ns tf (TG1, TG2) Top Gate Fall Time CL = 3300pF (Note 6) 10 ns tr (BG1, BG2) Bottom Gate Rise Time CL = 3300pF (Note 6) 20 ns tf (BG1, BG2) Bottom Gate Fall Time CL = 3300pF (Note 6) 10 ns RDS(ON)(TG) Top Gate Pull-Down NMOS TG to SW 0.9 Ω TG1, TG2 On-Resistance RDS(ON)(BG) Bottom Gate Pull-Down NMOS BG to PGND 0.9 Ω BG1, BG2 On-Resistance IPK(TG) TG1, TG2 Top Gate (TG) Peak Source Current 1.0 A IPK(BG) BG1, BG2 Bottom Gate (BG) Peak Source Current 1.0 A tDEAD1 Bottom Gate Off to Top Gate On (Note 6) 30 ns Deadtime tDEAD2 Top Gate Off to Bottom Gate On (Note 6) 30 ns Deadtime tON(MIN) Minimum On-Time VCOMP = 1.25V (Note 6, 7) 65 ns
Note 1:
Note 6:
Guaranteed by design, not subject to test. may cause permanent damage to the device. Exposure to any Absolute
Note 7:
The minimum on-time condition corresponds to an inductor peak- Maximum Rating condition for extended periods may affect device to-peak ripple current of 50% of IMAX. See Applications Information for reliability and lifetime. Unless otherwise specifi ed, all voltages are relative more details. to SGND and all currents are positive into a pin.
Note 8:
The voltage positioning amplifi er operates as a transconductance
Note 2:
The LTC3811E is guaranteed to meet performance specifi cations amplifi er, where the input voltages are the SENSE+ to SENSE– potentials from 0°C to 85°C temperature. Specifi cations over the –40°C to for both channels. The amplifi er output current fl ows through an external 85°C operating junction temperature range are assured by design, resistor in order to program the amount of voltage droop at full load. characterization and correlation with statistical process controls.
Note 9:
The PHASEMODE function is only available in the QFN package.
Note 3:
TJ is calculated from the ambient temperature TA and power The 36-lead GW package has a fi xed channel 1-to-channel 2 phase dissipation PD according to the following formula: relationship of 180°C and a channel 1-to-CLKOUT phase relationship of TJ = TA + (PD • TBD°C/W) 90°C. The version in the 36-lead GW package is therefore optimized for
Note 4:
The dynamic input supply current is higher due to power 2- and 4-phase operation. MOSFET gate charging (QG • fOSC). See Applications Information for more
Note 10:
Rise and fall times are measured at 10% and 90% levels. information.
Note 5:
The error amplifi ers are measured in a feedback loop using an external servo operational amplifi er that drives the VFB pin and regulates VCOMP to be equal to the external control voltage. 3811f 5
