Datasheet MAX4322, MAX432, MAX4326, MAX4327, MAX4329 (Maxim)
ManufacturerMaxim
DescriptionSingle/Dual/Quad, Low-Cost, UCSP/SOT23, Low-Power, Rail-to-Rail I/O Op Amps
Pages / Page17 / 1 — Single/Dual/Quad, Low-Cost, UCSP/SOT23,. Low-Power, Rail-to-Rail I/O Op …
Revision3
File Format / SizePDF / 510 Kb
Single/Dual/Quad, Low-Cost, UCSP/SOT23,. Low-Power, Rail-to-Rail I/O Op Amps. MAX4322/MAX4323/MAX4326/MAX4327/MAX4329
Datasheet MAX4322, MAX432, MAX4326, MAX4327, MAX4329 Maxim, Revision: 3
19-1380; Rev 3; 10/02
Single/Dual/Quad, Low-Cost, UCSP/SOT23, Low-Power, Rail-to-Rail I/O Op Amps MAX4322/MAX4323/MAX4326/MAX4327/MAX4329 General Description ____________________________Features
The MAX4322/MAX4323/MAX4326/MAX4327/MAX4329 ♦
6-Bump UCSP Package (MAX4323)
family of operational amplifiers combines wide bandwidth ♦
2.4V to 6.5V Single-Supply Operation
and excellent DC accuracy with Rail-to-Rail® operation at the inputs and outputs. These devices consume only ♦
Rail-to-Rail Input Common-Mode Voltage Range
650µA per amplifier and operate from either a single sup- ♦
Rail-to-Rail Output Voltage Swing
ply (2.4V to 6.5V) or dual supplies (±1.2V to ±3.25V). These unity-gain-stable amplifiers are capable of driving 250Ω ♦
5MHz Gain-Bandwidth Product
loads and have a 5MHz gain-bandwidth product. The ♦
650µA Quiescent Current per Amplifier
MAX4323 and MAX4327 feature a low-power shutdown mode that reduces supply current to 25µA and places the ♦
700µV Offset Voltage
outputs in a high-impedance state. ♦
No Phase Reversal for Overdriven Inputs
With their rail-to-rail input common-mode range and ♦
Drive 250
Loads
output swing, these amplifiers are ideal for low-voltage, single-supply operation. In addition, low offset voltage ♦
25µA Shutdown Mode (MAX4323/MAX4327)
and high speed make them the ideal signal-condition- ♦
Unity-Gain Stable for Capacitive Loads
ing stages for precision, low-voltage data-acquisition
Up to 500pF
systems. The MAX4323 is offered in a small 6-bump chip-scale package (UCSP™). The MAX4322/MAX4323 are also
Ordering Information
available in space-saving SOT23 packages.
TEMP PIN/BUMP- TOP PART RANGE PACKAGE MARK Selector Guide MAX4322
EUK-T -40oC to +85oC 5 SOT23-5 ACGE MAX4322EUA -40oC to +85oC 8 µMAX —
BW NO. OF PIN/BUMP- PART SHUTDOWN (MHz) AMPS PACKAGE
MAX4322ESA -40oC to +85oC 8 SO —
Ordering Information continued at end of data sheet.
5 SOT23, MAX4322 5 1 — 8 µMAX/SO
Pin Configurations
6 SOT23/UCSP, MAX4323 5 1 Yes 8 µMAX/SO TOP VIEW MAX4326 5 2 8 µMAX/SO — (BUMPS ON BOTTOM) B A MAX4327 5 2 10 µMAX, 14 SO Yes MAX4329 5 4 14 SO — 1 IN+ VEE
________________________Applications
MAX4323 Battery-Powered Data-Acquisition Instruments Systems 2 IN- OUT RSSI Systems Signal Conditioning PA Biasing Portable Equipment Low-Power, Low-Voltage Applications 3 V SHDN CC
UCSP
Rail-to-Rail is a registered trademark of Nippon Motorola, Ltd. Pin Configurations continued at end of data sheet. UCSP is a trademark of Maxim Integrated Products, Inc.
________________________________________________________________ Maxim Integrated Products 1 For pricing, delivery, and ordering information, please contact Maxim/Dallas Direct! at 1-888-629-4642, or visit Maxim’s website at www.maxim-ic.com.
