Datasheet MAX4322, MAX432, MAX4326, MAX4327, MAX4329 (Maxim) - 7
ManufacturerMaxim
DescriptionSingle/Dual/Quad, Low-Cost, UCSP/SOT23, Low-Power, Rail-to-Rail I/O Op Amps
Pages / Page17 / 7 — Single/Dual/Quad, Low-Cost, UCSP/SOT23,. Low-Power, Rail-to-Rail I/O Op …
Revision3
File Format / SizePDF / 510 Kb
Single/Dual/Quad, Low-Cost, UCSP/SOT23,. Low-Power, Rail-to-Rail I/O Op Amps. MAX4322/MAX4323/MAX4326/MAX4327/MAX4329
Single/Dual/Quad, Low-Cost, UCSP/SOT23, Low-Power, Rail-to-Rail I/O Op Amps MAX4322/MAX4323/MAX4326/MAX4327/MAX4329
Single/Dual/Quad, Low-Cost, UCSP/SOT23, Low-Power, Rail-to-Rail I/O Op Amps MAX4322/MAX4323/MAX4326/MAX4327/MAX4329 _____________________________Typical Operating Characteristics (continued)
(VCC = 5V, VEE = 0V, VCM = VCC/2, SHDN = VCC, TA = +25°C, unless otherwise noted.)
LARGE-SIGNAL GAIN MINIMUM OPERATING VOLTAGE TOTAL HARMONIC DISTORTION vs. TEMPERATURE vs. TEMPERATURE PLUS NOISE vs. FREQUENCY
1.9 125 0.040 VCC = 6.5V, RL TO VEE AV = +1 120 1.8 0.035 2VP-P SIGNAL VCC = 6.5V, RL TO VCC MAX4322/26/29-20 115 MAX4322/26/29-19 MAX4322/26/29-21 500kHz LOWPASS FILTER 1.7 0.030 R 110 L = 10kΩ TO VCC/2 0.025 105 1.6 100 V 0.020 CC = 2.7V, RL TO VEE GAIN (dB) 1.5 95 THD + N (%) 0.015 VCC = 2.7V, RL TO VCC 90 1.4 0.010 85 MINIMUM OPERATING VOLTAGE (V) VOUT(P-P) = VCC - 600mV 1.3 0.005 80 RL = 100kΩ 75 1.2 0 -40 -25 -10 5 20 35 50 65 80 95 -40 -25 -10 5 20 35 50 65 80 95 10 100 1k 10k 100k TEMPERATURE ( TEMPERATURE ( °C) °C) FREQUENCY (Hz)
TOTAL HARMONIC DISTORTION PLUS NOISE SMALL-SIGNAL TRANSIENT SMALL-SIGNAL TRANSIENT vs. PEAK-TO-PEAK SIGNAL AMPLITUDE RESPONSE (NONINVERTING) RESPONSE (INVERTING)
0.1 A A V = +1 V = +1 AV = -1 10kHz SINE WAVE RL TO VCC/2 MAX4322/26/29-23 MAX4322/26/29-22 MAX4322/26/29-24 500kHz LOWPASS FILTER IN IN 0.01 RL = 2kΩ RL = 250Ω THD + N (%) VOLTAGE (50mV/div) VOLTAGE (50mV/div) OUT OUT RL = 10kΩ RL = 100kΩ 0.001 4.0 4.2 4.4 4.6 4.8 5.0 200ns/div 200ns/div PEAK-TO-PEAK SIGNAL AMPLITUDE (V)
LARGE-SIGNAL TRANSIENT LARGE-SIGNAL TRANSIENT RESPONSE (NONINVERTING) RESPONSE (INVERTING)
AV = +1 AV = -1 MAX4322/26/29-25 MAX4322/26/29-26 IN IN VOLTAGE (2V/div) VOLTAGE (2V/div) OUT OUT 2µs/div 2µs/div
_______________________________________________________________________________________ 7
