Datasheet ADAU1401A (Analog Devices) - 2
DescriptionSigmaDSP 28-/56-Bit Audio Processor with Two ADCs and Four DACs
Pages / Page52 / 2 — ADAU1401A. TABLE OF CONTENTS
File Format / SizePDF / 930 Kb
ADAU1401A TABLE OF CONTENTS
link to page 1 link to page 1 link to page 1 link to page 1 link to page 3 link to page 4 link to page 4 link to page 5 link to page 6 link to page 6 link to page 6 link to page 6 link to page 7 link to page 10 link to page 10 link to page 10 link to page 11 link to page 14 link to page 15 link to page 16 link to page 17 link to page 17 link to page 17 link to page 17 link to page 17 link to page 18 link to page 18 link to page 19 link to page 20 link to page 21 link to page 22 link to page 23 link to page 23 link to page 23 link to page 26 link to page 27 link to page 29 link to page 29 link to page 29 link to page 30 link to page 30 link to page 30 link to page 30 link to page 30 link to page 32 link to page 34 link to page 34 link to page 34 link to page 35 link to page 36 link to page 36 link to page 37 link to page 37 link to page 37 link to page 37 link to page 38 link to page 38 link to page 39 link to page 40 link to page 41 link to page 42 link to page 42 link to page 43 link to page 43 link to page 43 link to page 43 link to page 43 link to page 44 link to page 44 link to page 44 link to page 44 link to page 47 link to page 47 link to page 47 link to page 48 link to page 48 link to page 49 link to page 49 link to page 49 link to page 50 link to page 51 link to page 51
Features .. 1  Address Maps.. 30  Applications... 1  Parameter RAM.. 30  General Description ... 1  Data RAM ... 30  Functional Block Diagram .. 1  Read/Write Data Formats ... 30  Revision History ... 3  Control Register Map... 32  Specifications... 4  Control Register Details .. 34  Analog Performance .. 4  Address 2048 to Address 2055 (0x0800 to 0x0807)—Interface Digital Input/Output.. 5  Registers... 34  Power.. 6  Address 2056 (0x0808)—GPIO Pin Setting Register .. 35  Temperature Range .. 6  Address 2057 to Address 2060 (0x0809 to 0x080C)— Auxiliary ADC Data Registers.. 36  PLL and Oscillator.. 6  Address 2064 to Address 2068 (0x0810 to 0x0814)—Safeload Regulator.. 6  Data Registers ... 37  Digital Timing Specifications ... 7  Address 2069 to Address 2073 (0x0815 to 0x0819)—Safeload Absolute Maximum Ratings.. 10  Address Registers ... 37  Thermal Resistance .. 10  Address 2074 and Address 2075 (0x081A and 0x081B)—Data ESD Caution.. 10  Capture Registers.. 38  Pin Configuration and Function Descriptions... 11  Address 2076 (0x081C)—DSP Core Control Register .. 39  Typical Performance Characteristics ... 14  Address 2078 (0x081E)—Serial Output Control Register .. 40  System Block Diagram ... 15  Address 2079 (0x081F)—Serial Input Control Register ... 41  Theory of Operation .. 16  Address 2080 and Address 2081 (0x0820 and 0x0821)— Multipurpose Pin Configuration Registers... 42  Initialization .. 17  Address 2082 (0x0822)—Auxiliary ADC and Power Control Power-Up Sequence ... 17  Register .. 43  Control Registers Setup ... 17  Address 2084 (0x0824)—Auxiliary ADC Enable Register ... 43  Recommended Program/Parameter Loading Procedure ... 17  Address 2086 (0x0826)—Oscillator Power-Down Register . 43  Power Reduction Modes.. 17  Address 2087 (0x0827)—DAC Setup Register ... 43  Using the Oscillator.. 18  Multipurpose Pins .. 44  Setting Master Clock/PLL Mode .. 18  Auxiliary ADC.. 44  Voltage Regulator ... 19  General-Purpose Input/Output Pins... 44  Audio ADCs .. 20  Serial Data Input/Output Ports .. 44  Audio DACs .. 21  Layout Recommendations... 47  Control Ports... 22  Parts Placement .. 47  I2C Port .. 23  Grounding ... 47  SPI Port .. 26  Typical Application Schematics.. 48  Self-Boot .. 27  Self-Boot Mode... 48  Signal Processing .. 29  I2C Control .. 49  Numeric Formats.. 29  SPI Control.. 50  Programming .. 29  Outline Dimensions ... 51  RAMs and Registers ... 30  Ordering Guide .. 51  Rev. A | Page 2 of 52 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ANALOG PERFORMANCE DIGITAL INPUT/OUTPUT POWER TEMPERATURE RANGE PLL AND OSCILLATOR REGULATOR DIGITAL TIMING SPECIFICATIONS Digital Timing Diagrams ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS SYSTEM BLOCK DIAGRAM THEORY OF OPERATION INITIALIZATION POWER-UP SEQUENCE CONTROL REGISTERS SETUP DSP Core Control Register (Address 2076) DAC Setup Register (Address 2087) RECOMMENDED PROGRAM/PARAMETER LOADING PROCEDURE POWER REDUCTION MODES USING THE OSCILLATOR SETTING MASTER CLOCK/PLL MODE VOLTAGE REGULATOR AUDIO ADCs AUDIO DACs CONTROL PORTS I2C PORT Addressing I2C Read and Write Operations SPI PORT Chip Address, R/ Subaddress Data Bytes SELF-BOOT EEPROM Format Writeback SIGNAL PROCESSING NUMERIC FORMATS Numerical Format: 5.23 PROGRAMMING RAMS AND REGISTERS ADDRESS MAPS PARAMETER RAM Direct Read/Write Safeload Write DATA RAM READ/WRITE DATA FORMATS CONTROL REGISTER MAP CONTROL REGISTER DETAILS ADDRESS 2048 TO ADDRESS 2055 (0x0800 TO 0x0807)—INTERFACE REGISTERS ADDRESS 2056 (0x0808)—GPIO PIN SETTING REGISTER ADDRESS 2057 TO ADDRESS 2060 (0x0809 TO 0x080C)—AUXILIARY ADC DATA REGISTERS ADDRESS 2064 TO ADDRESS 2068 (0x0810 TO 0x0814)—SAFELOAD DATA REGISTERS ADDRESS 2069 TO ADDRESS 2073 (0x0815 TO 0x0819)—SAFELOAD ADDRESS REGISTERS ADDRESS 2074 AND ADDRESS 2075 (0x081A AND 0x081B)—DATA CAPTURE REGISTERS ADDRESS 2076 (0x081C)—DSP CORE CONTROL REGISTER ADDRESS 2078 (0x081E)—SERIAL OUTPUT CONTROL REGISTER ADDRESS 2079 (0x081F)—SERIAL INPUT CONTROL REGISTER ADDRESS 2080 AND ADDRESS 2081 (0x0820 AND 0x0821)—MULTIPURPOSE PIN CONFIGURATION REGISTERS ADDRESS 2082 (0x0822)—AUXILIARY ADC AND POWER CONTROL REGISTER ADDRESS 2084 (0x0824)—AUXILIARY ADC ENABLE REGISTER ADDRESS 2086 (0x0826)—OSCILLATOR POWER-DOWN REGISTER ADDRESS 2087 (0x0827)—DAC SETUP REGISTER MULTIPURPOSE PINS AUXILIARY ADC GENERAL-PURPOSE INPUT/OUTPUT PINS SERIAL DATA INPUT/OUTPUT PORTS LAYOUT RECOMMENDATIONS PARTS PLACEMENT GROUNDING TYPICAL APPLICATION SCHEMATICS SELF-BOOT MODE I2C CONTROL SPI CONTROL OUTLINE DIMENSIONS ORDERING GUIDE AUTOMOTIVE PRODUCTS
