Datasheet LT8705A (Analog Devices) - 7
Description80V VIN and VOUT Synchronous 4-Switch Buck-Boost DC/DC Controller
Pages / Page44 / 7 — Typical perForMance characTerisTics TA = 25°C unless otherwise specified. …
File Format / SizePDF / 657 Kb
Typical perForMance characTerisTics TA = 25°C unless otherwise specified. Efficiency vs Output Current
Typical perForMance characTerisTics TA = 25°C unless otherwise specified Efficiency vs Output Current
LT8705A
Typical perForMance characTerisTics TA = 25°C unless otherwise specified. Efficiency vs Output Current Efficiency vs Output Current Efficiency vs Output Current (Boost Region-Figure 15) (Buck-Boost Region-Figure 15) (Buck Region-Figure 15)
100 100 100 90 90 90 80 80 80 70 70 70 60 60 60 50 50 50 40 40 40 EFFICIENCY (%) EFFICIENCY (%) EFFICIENCY (%) 30 VIN = 36V 30 VIN = 48V 30 VIN = 72V VOUT = 48V VOUT = 48V VOUT = 48V 20 BURST 20 BURST 20 BURST 10 FCM 10 FCM 10 FCM DCM DCM DCM 0 0 0 10 100 1000 10000 10 100 1000 10000 10 100 1000 10000 LOAD CURRENT (mA) LOAD CURRENT (mA) LOAD CURRENT (mA) 8705A G01 8705A G02 8705A G03
Feedback Voltages FBOUT Voltages (Five Parts) Oscillator Frequency
1.23 1.23 400 VC = 1.2V VC = 1.2V RT = 124k 350 1.22 1.22 300 1.21 1.21 250 RT = 215k 1.20 1.20 200 150 PIN VOLTAGE (V) 1.19 FREQUENCY (kHz) RT = 365k FBOUT VOLTAGE (V) 1.19 IMON_OUT 100 1.18 IMON_IN 1.18 FBOUT 50 FBIN 1.17 1.17 0 –55 –30 –5 20 45 70 95 120 145 –45 –20 5 30 55 80 105 130 –40 –20 0 20 40 60 80 100 120 TEMPERATURE (°C) TEMPERATURE (°C) TEMPERATURE (°C) 8705A G04 8705A G05 8705A G06
Maximum Inductor Current Sense Inductor Current Sense Voltage at Maximum Inductor Current Sense Voltage vs Duty Cycle Minimum Duty Cycle Voltage at Minimum Duty Cycle
140 120 120 120 BUCK REGION BOOST REGION 100 100 120 100 80 80 100 60 60 CSP-CSN (mV) 80 BUCK REGION 40 40 80 BOOST REGION BUCK REGION 20 20 60 60 BOOST REGION 0 0 |CSP-CSN| (mV) CSN-CSP (mV) |CSP-CSN| (mV) 40 40 –20 –20 –40 –40 20 20 –60 –60 0 –80 –80 0 0 20 40 60 80 100 0.5 1 1.5 2 –40 –20 0 20 40 60 80 100 120 M2 OR M3 DUTY CYCLE (%) VC (V) TEMPERATURE (°C) 8705A G07 8705A G08 8705A G09 8705af For more information www.linear.com/LT8705A 7 Document Outline Features Description Applications Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Operation Applications Information Typical Applications Package Description Typical Application Related Parts
