Datasheet LTM2886 (Analog Devices) - 2
DescriptionSPI/Digital or I2C μModule Isolator with Fixed ±5V and Adjustable 5V Regulated Power
Pages / Page38 / 2 — ABSOLUTE MAXIMUM RATINGS. (Note 1). PIN CONFIGURATION
ABSOLUTE MAXIMUM RATINGS (Note 1) PIN CONFIGURATION
LTM2886
VCC to GND .. –0.3V to 6V Logic Outputs VL to GND .. –0.3V to 6V DO1, DO2, SDO to GND ..–0.3V to (VL + 0.3V) VCC2, AVCC2 to GND2 ... –0.3V to 6V O1, SCK2, SDI2, CS2, V+ to GND2 .. –0.3V to 6V SCL2 to GND2 ..–0.3V to (VCC2 + 0.3V) V– to GND2 .. 0.3V to –6V Operating Temperature Range (Note 4) Logic Inputs LTM2886C ... 0°C to 70°C DI1, SCK, SDI, CS, SCL, SDA, SDOE, LTM2886I ..–40°C to 85°C ON to GND ..–0.3V to (VL + 0.3V) LTM2886H ... –40°C to 125°C I1, I2, SDA2, Maximum Internal Operating Temperature .. 125°C SDO2 to GND2 ..–0.3V to (VCC2 + 0.3V) Storage Temperature Range .. –55°C to 125°C Peak Body Reflow Temperature .. 245°C
PIN CONFIGURATION
LTM2886-I LTM2886-S TOP VIEW TOP VIEW 1 2 3 4 5 6 7 8 1 2 3 4 5 6 7 8 DO2 DNC SCL SDA DI1 GND ON VL SDO DO2 SCK SDI CS SDOE ON VL A A B B DO1 GND V C CC DO1 GND V C CC D D E E F F G G H H J I1 GND2 AVCC2 GND2 J I1 GND2 AVCC2 GND2 K K L L I2 DNC SCL2 SDA2 O1 VCC2 V– V+ SDO2 I2 SCK2 SDI2 CS2 VCC2 V– V+ BGA PACKAGE BGA PACKAGE 32-PIN (15mm × 11.25mm × 3.42mm) 32-PIN (15mm × 11.25mm × 3.42mm) TJMAX = 125°C, θJA = 25.5°C/W, θJC(BOTTOM) = 9.2°C/W, TJMAX = 125°C, θJA = 25.5°C/W, θJC(BOTTOM) = 9.2°C/W, θJC(TOP) = 16.6°C/W, θJBOARD = 9.9°C/W θJC(TOP) = 16.6°C/W, θJBOARD = 9.9°C/W θ VALUES DETERMINED PER JESD51-9, WEIGHT = 1.2g θ VALUES DETERMINED PER JESD51-9, WEIGHT = 1.2g 2886fb 2 For more information www.linear.com/LTM2886 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Product Selection Guide Order Information Electrical Characteristics Switching Characteristics Isolation Characteristics Typical Performance Characteristics Pin Functions Block Diagrams Test Circuits Applications Information Typical Applications Package Description Typical Application Related Parts
